oil fitting part numbers.
Old Oct 9, 2001 | 09:49 AM
pagong's Avatar
Default oil fitting part numbers.
Can somebody post up all the part numbers for the T-fitting from the oil pressure sensor all the way to the turbo, then from the turbo all the way down the oil pan.???
Old Oct 9, 2001 | 09:53 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: oil fitting part numbers. (pagong)
. You can buy the flange and gasket from either Turbonetics or http://www.majesticturbo.com . The part # is PN 20259.
1. 90 deg. -10AN to 1/2"Male pipe threads Part # 829010
2. -10 Stainless briaded line. You can get away with 1ft, but I got 2" just in case. Perfomo flex is what I use.
3. 45Deg. Swivel-Seal Hose End Male Threaded 1/2" to -10 part #824510
4. brass 1/2" NPT female fittings - to weld in oil pan (dont have a part # or pic)
Hope this helps. And these are from ANplumbing.com.
I dont have the T fitting for the oil pressure sensor.
art
Old Oct 9, 2001 | 11:11 AM
93LSivic's Avatar
https://honda-tech.com/zerothread?id=73258
I got some of the parts that you need. --For the dump line. Check it. I have one person waiting but havent heard anything from him yet.
Old Oct 18, 2001 | 10:33 AM
Etylorcen's Avatar
Default Re: oil fitting part numbers. (Arturbo)
What is the flange for? So the 1/2'' npt female gets welded into the oil pan then the 90 degree -10AN to the 1/2'' male pipe goes into the 1/2'' female then run the steel braided line to the 45 degree swivel seal 1/2'' to -10an into the turbo. Is that how it goes?
solo2fresh
Mar 2, 2011 04:09 PM
UNforgivABLE
Mar 19, 2006 07:13 AM
Cowboy
Jun 8, 2003 10:01 AM
TurbothisLS
Sep 11, 2002 09:29 AM
Peter K
Aug 29, 2001 09:58 PM
