need help with Oil Pressure sensor...
i finished installing the turbo except the oil feed and release line.
does anyone know where the oil pressure sensor is on the '00 prelude?
and what's the best way to make the hole in the oil pan, because not many welding shops will weld alumium for me.
thanks!
thanks!
i just did this last night on my car. The oil pressure sensor is located right above the intermediate shaft, under the oil filter. Unscrew the phillops head screw, undo the wire, then i used a big cresent wrench to take it off, i'll have pics tonight.
cool, thanks....
i have an idea of where it is now.
are you also installing a turbo? how did you take off the oil pan to attach your oil return line? i took off all the bolts but honda sealed the oil pan with some silicone glue around the rim of the oil pan and it's a bitch to remove. any ideas?
