has anyone used jb weld on thier oil leaks??
Location: home of Marciano/Haggler, city of champions, MA
im having bad oil leak problems and i just bought jb weld. it comes with 2 small tubes of chemicals. one is the steal material and the other is the hardener. has anyone here used this stuff on thier oil leaks?
Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource »</TD></TR><TR><TD CLASS="quote">I used it on a bung that was threaded into my oil pan for an oil return line. . . held up for the year that the car was boosted.</TD></TR></TABLE>
thats axactly what i needed to use it for. thanks
Re: has anyone used jb weld on thier oil leaks?? (h22boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy »</TD></TR><TR><TD CLASS="quote">has anyone here used this stuff on thier oil leaks?
how big is the leak...i once had a hairpin size hole on my oil pan. I believe I used quicksteel, its held up for over 2 years plus it can withstand 500 degrees
Re: has anyone used jb weld on thier oil leaks?? (Deluzional)
my friend used it to patch a hole in his oil pan after slamming on the ground for the 1000th time. it worked well ( this was quicksteel actually)
right now my return line is leaking at the oil pan, ive got both regular jb weld and then additional quicksteel on it.
I too had a leak on my oil pan return line. I had my budyd tig weld an AN fitting and it was leaking a decent amount somewhere. I didn't know where so I gobbed JB weld around the welds all voer, let it set, then applied anotehr layer after that the next day. Been boosting for a while. it's perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional »</TD></TR><TR><TD CLASS="quote">
how big is the leak...i once had a hairpin size hole on my oil pan. I believe I used quicksteel, its held up for over 2 years plus it can withstand 500 degrees </TD></TR></TABLE> my leak is about 2 quarts a weak. ill see how this jb stuff works. if that aint enough ill use quicksteel.
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">I too had a leak on my oil pan return line. I had my budyd tig weld an AN fitting and it was leaking a decent amount somewhere. I didn't know where so I gobbed JB weld around the welds all voer, let it set, then applied anotehr layer after that the next day. Been boosting for a while. it's perfect.</TD></TR></TABLE>
Same here. LOL. Works great.
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote"> track will give you **** for having an oil leak</TD></TR></TABLE>
i know thats why im trying to get a run out of it before i get rid of it. i didnt drive it at all today to let it dry. ill check it tomm to see how things are going
D16y8_619
09-08-2006 09:05 PM
