Oil Feed recommendation...
Old Mar 15, 2011 | 03:56 PM
B18C-Hatch-Turbo's Avatar
Default Oil Feed recommendation...
Oil Filter Sandwich or T-fitting in stock pressure location - read a bunch of stuff from the FAQ section (even though most pics are missing....)
I need to feed the turbo and want accurate pressure and temp readouts....which location is best (also is jury still out on whether sandwich plate sends 'unfiltered' oil to turbo - does the oil tap location actually bypass the filter)
T-fitting hangs out kinda far and with solid motors mounts and traction bar I am worried about the vibration - don't really want to mount to fire wall.
For sensors I assume the hondata (well ECU) can read the stock oil temp & pressure or should i get gauges...where is the oil temp sensor (does B18C just use a coolant temp sensor)
Thanks,
Old Mar 15, 2011 | 06:03 PM
dpetro1's Avatar
Default Re: Oil Feed recommendation...
hondata cannot read oil temp or pressure unless you add the sensor manually and run then to the aux inputs. reason is because there is no factory sensor to measure these things. oil pressure is just a switch that cuts on under 5 psi.
for your original question, get a sandwich plate if you dont want to remote mount the aftermarket pressure sender.
Old Mar 15, 2011 | 06:09 PM
so that pressure sensor just trips the oil light when it's under 5psi?
is measuring the oil pressure and temp at the oil filter interface a good read, where is the ideal location?
Also any input on this:
http://cgi.ebay.com/ebaymotors/Oil-S...#ht_3797wt_970
Figure might as well get a 3 port - don't know of any name brand 3 port adapters.....anyone know of one?
Old Mar 16, 2011 | 06:08 AM
7rrivera7's Avatar
So when my mechanic removed the switch/sensor to run an oil line directly to a oil pressure gauge, he didn't choose the best method right?
Old Mar 16, 2011 | 06:43 AM
does your oil light come on? He may have used a tee so the factory sensor is still there
Old Mar 16, 2011 | 08:18 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
There are filtered sandwich plates available, GE and Mfactory I believe.
You could also run an inline filter in you don't use a filtered plate.
Old Mar 16, 2011 | 03:53 PM
dpetro1's Avatar
I generally stay away from eBay. If the line or sandwich adapter fails you lose a motor. Grab a ge or equivalent.
Its a fine method. You should get an aftermarket oil pressure gauge anyways. They are cheap insurance. Also you can still check to see if the own sensor is plugged in.
Old Mar 16, 2011 | 06:28 PM
wantboost's Avatar
Who is Mr Robot?
Honestly the sotck sender/light is pointless... once oil pressures drop that low you have a problem anyways...
either do a tee off of the stock sending unit (remote mount the sending unit so it doesnt snap in half) or use a sandwich plate.
I run an inline filter on the turbo feed just to be safe regardless of choice
Old Mar 16, 2011 | 07:01 PM
JDM B20 EH2's Avatar
I used a T setup off the stock sending unit location. It worked fine last time and everything seems like its goin to work ok this time too.
velisma
Jan 30, 2010 08:24 PM
JDM_Acccord
Jul 5, 2007 09:29 AM
hondaeg8
Jul 28, 2005 05:10 AM
JforJonathan
Apr 17, 2005 10:47 AM
accordfreak
Jan 27, 2004 12:52 PM
