oil cooler on lsv setup
Old Dec 4, 2010 | 08:37 AM
  #26
sgcrichi's Avatar
Default Re: oil cooler on lsv setup
Locate the original equipment manufacturer (OEM) oil port holes for the addition of an oil cooler, or drill the appropriate holes manually. Drilled holes should be positioned so that there is one line going from the oil pan and one leading to the oil pump. Oil pumps can be located in different places on any given motor and should have an adapter hole or drill point nearby. Detailed engine schematics should be obtained when drilling these holes to ensure that they are in ideal locations.
Couple the oil line adapters to the holes and secure them tightly with the bolts provided in the kit. These "line" bolts have hollow centers that allow oil to flow through them.
Route the oil line tubes or hoses to the front of the vehicle and secure them away from other engine equipment if possible. Most oil cooler kits will come with right-angle adapters for making difficult bends or linking the hose with the oil radiator.
Mount the oil radiator and link it to the oil lines. The oil cooler system will be empty until filled by starting the car, and a quart or two of extra oil should be added until the system is full.
Old Dec 8, 2010 | 09:15 AM
  #27
skateboard_ej8's Avatar
im hench irl
Pics of set-ups would help.
Old Dec 8, 2010 | 05:31 PM
  #28
up&atam's Avatar
Your head lifted? I think you need to invest in headstuds and or retard your timing. I run my feed and return off the sandwich plate to the oil cooler, and I don't seem to have any problems. I'm not boosting 17psi tho
Originally Posted by Blacksi76
my head lifted and breached my headgasket so I gotta replace that over the winter, and it wasn't from detonation cause i was running 100 Octane fuel, and after the tuning session, I drove the car around normally and everything was fine, went into boost a few times and it was fine, but only noticed the coolant overflow...overflowing after I had gone into full boost a few times when I was testing it out....
Old Dec 9, 2010 | 09:03 AM
  #29
Blacksi76's Avatar
Yeah it was the 4th usage on the ARP Headstuds, so I have been told that they were prob stretched anyways, so another new set of headstuds, and a new Headgasket, I am hoping I should be good to go..
Old Dec 10, 2010 | 04:32 PM
  #30
sh!ft's Avatar
Who the fack changed my title?!
any one know if you can use a b16 oil cooler on an ls block?
b20ricepower
Jul 7, 2013 09:44 PM
diablo2184
Jan 16, 2012 10:10 AM
Agito
Dec 14, 2007 07:23 PM
mike1114
Oct 30, 2006 06:26 AM
T-sohctec
Apr 21, 2003 04:36 AM
