Oil in the Charge Pipe?????????????????????????????
Old Dec 3, 2002 | 12:57 PM
I Like Boost's Avatar
Default Oil in the Charge Pipe?????????????????????????????
today i removed my blow off valve and saw some oil on the flange, i reached inside and felt oil in the chrge pipe. how could this be and what is wrong.
Old Dec 3, 2002 | 01:05 PM
inconel's Avatar
Default Re: Oil in the Charge Pipe????????????????????????????? (BEe18SeAONe)
I could only think of one thing. (TURBO)
Old Dec 3, 2002 | 05:46 PM
Default Re: Oil in the Charge Pipe????????????????????????????? (inconel)
ya but is this normal
Old Dec 3, 2002 | 05:49 PM
B18EG6's Avatar
thats a tell tale sign of needing new turbo seals
Old Dec 3, 2002 | 05:53 PM
MiraiZ's Avatar
Default Re: Oil in the Charge Pipe????????????????????????????? (B18EG6)
no... it could be blowby if he's got the crankcase breather routed to the intake pipe
check your PCV valve
[Modified by MiraiZ, 11:54 AM 12/4/2002]
Old Dec 3, 2002 | 06:16 PM
Default Re: Oil in the Charge Pipe????????????????????????????? (MiraiZ)
i dont have it routed to my charge pipe, i'm gonna look at the pipes right after the turbo, for oil in the morning.
Old Dec 3, 2002 | 06:22 PM
lazerus's Avatar
Most turbo's secrete small amounts of oil due to the style seal that they use. Dynamic seals coupled with stepped piston rings are the best. most likely you have the latter, which is carbon seal and a 'straight thru' piston ring seal.
A small amount of oil is normal really. In fact, i've never seen an intercooler which did not have oil in the bottom after a fair amount of time coupled with a turbocharger.
The only way to avoid/help eliminate the problem is thus, dynamic seals and stepped piston ring seal in the turbocharger.
[Modified by lazerus, 7:22 PM 12/3/2002]
Old Dec 3, 2002 | 06:24 PM
Default Re: Oil in the Charge Pipe????????????????????????????? (lazerus)
ok thanks for the info
[Modified by BEe18SeAONe, 11:20 PM 12/3/2002]
Old Dec 3, 2002 | 09:11 PM
any other info
Old Dec 4, 2002 | 08:47 AM
anyone else ever get oil all the way by the bov flange?
Old Dec 4, 2002 | 08:59 AM
boostin b16's Avatar
i have a greddy type s bov and at times when i am running really high boost(in excess of 1.3 bar) or just whenever, i get some oil comming out of the blow off. this is compleatly normal, in fact all of the after market turbo cars i have ever seen have had a little oil up there. your oil level also matters, if you have too much oil in the motor it will happen too. just keep an eye on it because it can be a sign of a bad turbo or possibly other internal problems. but for your motors sake, every so often take off your harge pipe ans clean it and your throttle body out with some throttle body cleaner. it will give you slightly better performance as well as a cleaner running car.
[Modified by boostin b16, 6:00 PM 12/4/2002]
[Modified by boostin b16, 6:01 PM 12/4/2002]
Old Dec 4, 2002 | 09:05 AM
The Mole's Avatar
Default Re: Oil in the Charge Pipe????????????????????????????? (boostin b16)
normal...maybe, im not sure so i cant say, but it would make me nervous!!!
me and rainmanEK are currently rebuilding a turbo gsr hatch that destroyed some ringlads and his seals are also bad on turbo...and it has lots of play in it...and there was like...a lot of oil in charge pie...not a lil...like half quort
chris
Old Dec 4, 2002 | 11:31 AM
DIRep972's Avatar
Smarter than you
i dont have it routed to my charge pipe.
hehe just for luaghs im gonna bring up a story. I know a guy who did that. He ran his crank case breather line to the charge pipe instead of the intake pipe. take a guess what happens when boost goes in the head through the crank case breather.
Old Dec 4, 2002 | 11:44 AM
bretx0r's Avatar
yeah, if u have a turbo and u want to see your car smoke more than a LA crackhead, do this.
Old Dec 4, 2002 | 12:24 PM
Default Re: Oil in the Charge Pipe????????????????????????????? (bretx0r)
thanks for replys, i think i fucked up my turbo during the engine break in period after i got my block rebuilt. i was running the car with the blow off valve off of the flange so the motor would see no boost. so the turbo was just spinning crazy fast, it was spooling so loud it sounded like a bus. i checked and i'm not loseing any oil and the exhaust does not smoke at all.
Old Dec 4, 2002 | 01:28 PM
if the turbo is fucked then in most cases the exhaust will smoke terribly during deceleration or heavy throttle. it mayjust be normal oil, have someone ride behind u and go from 5th to 3rd and ride it out. then try 5th to 3rd and get on it. check for smoke. if you turbo is bad then it will smoke out the exhaust.
Old Dec 4, 2002 | 03:58 PM
no smoke out the exhaust at wot, im confused
Old Dec 4, 2002 | 05:54 PM
whta about declleration? thats the tell tale sign
Old Dec 4, 2002 | 07:38 PM
PressurizedSi's Avatar
My buddy has the same thing. I mean there was oil in the I/C, charge pipe, and BOV. Appearantly the seal in the turbo let loose allowing oil to escape into the sealed piping. We removed the turbo and put the stock mani back on. What a mess. With only a short ram the car idles alot better than before. I will be sending the turbo for inspection this week to see what happened.
Old Dec 4, 2002 | 09:30 PM
Default Re: Oil in the Charge Pipe????????????????????????????? (PressurizedSi)
Let me know what you guys find, this turbo was used for like 1500 miles so i hoipe its not messed up
Old Dec 4, 2002 | 10:07 PM
filetofit
Guest
Posts: n/a
Default Re: Oil in the Charge Pipe????????????????????????????? (DIRep972)
Oh man, did it force the oil out the dipstick tube?
crvtkllr
Apr 29, 2007 01:33 PM
GdmLaz
Jun 24, 2006 08:32 PM
tvic
Sep 13, 2005 06:33 PM
tony n.
Aug 6, 2005 09:15 AM
djnikko
Aug 12, 2003 06:28 AM
