IS an O2 simulator needed for obd2 with high flow cat?
Old 08-18-2003, 09:10 AM
hotboi850's Avatar
Default IS an O2 simulator needed for obd2 with high flow cat?
Just wondering if an O2 simulator is needed if I plan to run a high flow cat?
I'm thinking that I do because when I went to the muffler shop today to ask about my cat. they said my car needed an OBD2 compatible cat. Is this true?
Or could just get the high flow cat. and weld on a bung for the O2 sensor and not get any CEL codes?
Help me out please turbo going in soon
Old 08-18-2003, 09:14 AM
New User
TurboSedan's Avatar
Default Re: IS an O2 simulator needed for obd2 with high flow cat? (hotboi850)
No, with OBD2 you will still use your secondary O2 sensor so a simulator is not necessary.
Old 08-18-2003, 09:16 AM
hotboi850's Avatar
Default Re: IS an O2 simulator needed for obd2 with high flow cat? (TurboSedan)
Hmm, i did a search and others have said they needed one.
Hey turbosedan how is urs setup?
btw..im turboing my sedan too.hhehe
Old 08-18-2003, 09:29 AM
TOFU.man's Avatar
yes an o2 simulator is needed to keep from throwing the CEL. BUT there is a jerry rigged way to do it and that is to wrap aluminum foil around the o2 sensor tip where it reads from. BUt that is not reliable i would go with the O2 simulator for $50 it is worth it.
Old 08-18-2003, 07:55 PM
hotboi850's Avatar
Conflicting replys..ok i guess i'll just have to try both ways an see what works
Old 08-18-2003, 08:46 PM
Teg4e's Avatar
i have a carsound highflow cat on my obd2, boosted integra. no cel's.
no2unenolife
11-15-2006 10:36 PM
AintegraA
10-07-2004 06:41 PM
piotrush
02-09-2004 09:28 PM
R-1303
06-24-2002 07:00 PM
JinMTVT
08-11-2001 08:01 PM
Quick Reply: IS an O2 simulator needed for obd2 with high flow cat?
