CEL 63 Help!!
Old Jun 24, 2002 | 11:37 AM
R-1303's Avatar
Default CEL 63 Help!!
DRAG 3 kit on my ITR, installed a o2 simulator and have carsound 3" hi flow cat, and custom 3" pipping cat back into apex n1 turbo....can anybody help me?!!?!?
CEL63= Intanke air temp and secondary 02 circut!?!?
Old Jun 24, 2002 | 11:49 AM
VaporTrail's Avatar
New User
Default Re: CEL 63 Help!! (R-1303)
why did you install a high flow cat and a o2 simulator?
Old Jun 24, 2002 | 02:03 PM
niedejb's Avatar
Default Re: CEL 63 Help!! (VaporTrail)
63 is the O2 sensor low/high voltage or slow response.
Old Jun 24, 2002 | 02:27 PM
Flamenco-T's Avatar
Default Re: CEL 63 Help!! (niedejb)
it's a slow response...it reads the O2 mixutre from the cat, but the O2 simulator resisted the voltage a lil too low otr not enough within the acceptable voltage..
for O2 simulator's purpose is to FOOL the O2 sensor by resisting the voltage.
if you have a carsound cat, I wouldn't put the O2 simulator, if you;re running no cat, try the O2 silmulator..
and make sure the O2 sensor is AFTER the Cat
Old Jun 24, 2002 | 06:14 PM
R-1303's Avatar
Default Re: CEL 63 Help!! (Flamenco-NA)
Thanks for the advice...i put the ot simulator on and its after the cat but still a CEL..i think im just gonna hang it up...in foil right???..also does that check engine light put my car into a sluggish mode becuase of emmissions???
Old Jun 24, 2002 | 07:00 PM
wwcivic's Avatar
New User
CEL 63 will NOT put your car into limp mode. its just there to annoy you.
apoptosis
Feb 9, 2008 10:51 PM
pizzamanprelude
Aug 2, 2006 03:26 PM
smkngsr
Apr 6, 2005 01:58 PM
Kyle244R948
Sep 19, 2004 01:37 PM
