IS an O2 simulator needed for obd2 with high flow cat?
Old Aug 18, 2003 | 09:10 AM
hotboi850's Avatar
Default IS an O2 simulator needed for obd2 with high flow cat?
Just wondering if an O2 simulator is needed if I plan to run a high flow cat?
I'm thinking that I do because when I went to the muffler shop today to ask about my cat. they said my car needed an OBD2 compatible cat. Is this true?
Or could just get the high flow cat. and weld on a bung for the O2 sensor and not get any CEL codes?
Help me out please turbo going in soon
Old Aug 18, 2003 | 09:14 AM
TurboSedan's Avatar
New User
Default Re: IS an O2 simulator needed for obd2 with high flow cat? (hotboi850)
No, with OBD2 you will still use your secondary O2 sensor so a simulator is not necessary.
Old Aug 18, 2003 | 09:16 AM
hotboi850's Avatar
Default Re: IS an O2 simulator needed for obd2 with high flow cat? (TurboSedan)
Hmm, i did a search and others have said they needed one.
Hey turbosedan how is urs setup?
btw..im turboing my sedan too.hhehe
Old Aug 18, 2003 | 09:29 AM
TOFU.man's Avatar
yes an o2 simulator is needed to keep from throwing the CEL. BUT there is a jerry rigged way to do it and that is to wrap aluminum foil around the o2 sensor tip where it reads from. BUt that is not reliable i would go with the O2 simulator for $50 it is worth it.
Old Aug 18, 2003 | 07:55 PM
hotboi850's Avatar
Conflicting replys..ok i guess i'll just have to try both ways an see what works
Old Aug 18, 2003 | 08:46 PM
Teg4e's Avatar
i have a carsound highflow cat on my obd2, boosted integra. no cel's.
no2unenolife
Nov 15, 2006 10:36 PM
AintegraA
Oct 7, 2004 06:41 PM
piotrush
Feb 9, 2004 09:28 PM
R-1303
Jun 24, 2002 07:00 PM
JinMTVT
Aug 11, 2001 08:01 PM
