not running any o2 sensor?
Old Jan 28, 2005 | 09:02 PM
  #76
b16h22a's Avatar
Default Re: (trentepic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trentepic &raquo;</TD></TR><TR><TD CLASS="quote">
the o2 sensor makes ecu run a lil lean like 15:1, then lil rich 14:1, during closed loop conditions constantly to make it build up o2 in the cat then burn off the hydrocarbons and stuff, as apposed to having an air pump</TD></TR></TABLE> the oxygen sensor does not make the engine do this the pcm tells the car to do this. however this stops anyways at high rpm when the pcm tells the injectors to stay open because they can not open and close fast enough to keep up with the engine speed
Old Jan 29, 2005 | 06:00 PM
  #77
SOHC_MShue's Avatar
Default Re: (b16h22a)
https://honda-tech.com/zero...31799 idiot
Old Feb 3, 2005 | 08:50 PM
  #78
trentepic's Avatar
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16h22a &raquo;</TD></TR><TR><TD CLASS="quote"> the oxygen sensor does not make the engine do this the pcm tells the car to do this. however this stops anyways at high rpm when the pcm tells the injectors to stay open because they can not open and close fast enough to keep up with the engine speed</TD></TR></TABLE>
i said "the o2 sensor makes ecu run a lil lean like 15:1, then lil rich 14:1, during closed loop conditions constantly to make it build up o2 in the cat then burn off the hydrocarbons and stuff, as apposed to having an air pump"
as u can tell i worded it kinda funny, but indeed did not imply the the o2 sensor itself plugs into the injectors and directly controls pulse width of the injectors.
and the fact of the matter is that while a narrow band o2 reading is better then nothing as a waring device of a lean condition, its is a terrible device to rely on, especially if u think it will actually make the ecu go into limp home mode every time so to speak (super rich etc.) u cannot rely on it to save ur engine, etc.
its also possible to be rich "enuff" to not even detonate but still over heat the pistons, and expand them until there ruined or nearly ruined, and destroy the sleeves cross hatch, or possibly even wear it out of round.
long story short, better then nothing, but u should have a wide band instead whenever possible.
maybe egt would be ok too i dunno though.
Ct93CB7
Apr 15, 2011 02:10 PM
stereo
Dec 2, 2008 07:26 PM
ken2830
Feb 1, 2008 12:09 AM
egizzle8
Apr 13, 2005 07:20 AM
