02 sensor
Old Apr 15, 2011 | 10:16 AM
Ct93CB7's Avatar
Default 02 sensor
I kno obd2 f22b1's call for two o2 sensors but im running it one a obd1 ecu which only has slots for one is it possible to splice a second 02 sensor in to the one i already have running???
Old Apr 15, 2011 | 02:10 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 02 sensor
Huh?
OBDII has two O2s as the second one checks catalyst efficiency
If you are running OBDI then there is no provision/programming for catalyst efficiency and only uses the primary O2.
Each O2 will have their own pigtail, do nut run O2s in parallel or series, the signal will be incorrect.
ToTriggerHappy
Jan 28, 2011 04:18 PM
stereo
Dec 2, 2008 07:26 PM
fafsa
Feb 3, 2005 08:50 PM
StreetwizeRacin2
Apr 6, 2004 03:16 PM
Nick7
Sep 10, 2003 08:47 PM
