not making any boost!
Old Feb 20, 2004 | 07:16 AM
evil b's Avatar
Default not making any boost!
i installed my drag 3 turbo kit last night and the turbo spools up and everything but im just not making any boost. any suggestions?
Old Feb 20, 2004 | 07:46 AM
B18C4-T's Avatar
Default Re: not making any boost! (whiteteg95)
Try checking your intercooler piping and make sure it's completely attached everywhere. Also check and make sure the fire ring on your wastegate is in place. If you pull the wastegate off there is a ring that goes between the wastegate and the mani. Larry
Old Feb 20, 2004 | 08:01 AM
racinskittle's Avatar
Default Re: not making any boost! (B18C4-T)
what are you using as an air filter?
Old Feb 20, 2004 | 08:11 AM
gdrum's Avatar
Default Re: not making any boost! (racinskittle)
Yea make sure there are no vac leaks...if you have any vac leaks in your piping it wont cause your setup to build or hold boost....I also had the o ring problem make sure ur vac lines are properly set up as well with the wastegate
skierGT
Jun 21, 2004 09:32 AM
blackfrohatch
Aug 26, 2003 06:47 AM
asianspeed
Feb 19, 2003 09:05 PM
xrtdac
Jun 12, 2002 08:24 PM
