Not boosting over 5 lbs?
Old Jun 16, 2004 | 03:03 PM
RotiEatter's Avatar
Ditto
Default Not boosting over 5 lbs?
My setup is a 1990 CRX, DRAG III kit, DIY MBC, DeltaGate 7 psi spring, Open DP, Hondata s200b. The wastegate opens at 5 psi, I used the MBC to turn it up to 10 psi. Then one night I noticed it was only boosting 5 psi. I turned up the MBC, stayed at 5 psi. I tightened down all couplers and still only 5 psi. No holes or rips in the couplers that I can see. Intercooler piping is fine also. The BOV is a HKS SSQV, bolt on the back is tightened down all the way. When i would get near 0 on my boost gauge I would usually hear the BOV flutter. So I took it 2-3 psi, didnt hear the bov at all. Unhooked the vacuum line going from MBC to wastegate so it should have boosted unlimited,but it stayed at 5 psi. I am down to it is either the turbo or the BOV. If I disconnect the vacuum line going to the BOV should it boost unlimited if that is infact my problem? I would try another BOV but it is a bitch to take off and I dont have access to another one. Please help, 5 psi sucks
RotiEatter's Avatar
Ditto
Default Re: Not boosting over 5 lbs? (RotiEatter)
I forgot to mention that I can hear the BOV at 5 psi.
Old Jun 16, 2004 | 03:24 PM
pip9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote"> If I disconnect the vacuum line going to the BOV should it boost unlimited if that is infact my problem? </TD></TR></TABLE>
no, that would be the wg. if u disconnect the bov u'll just get compressor surge
Old Jun 16, 2004 | 03:31 PM
USDM 4G VTEC's Avatar
by taking the BOV line off, u will not equialize the pressure on both sides of the BOV valve,.. wich means boost will open it if the air pressure is bigger than the srping rate
Old Jun 16, 2004 | 03:43 PM
JDMH22HATCH's Avatar
Default Re: Not boosting over 5 lbs? (USDM 4G VTEC)
How are you running all of your vacuum lines? Is there maybe a source that is not creating enough vacuum or maybe too many lines running off of one small line?
Old Jun 17, 2004 | 06:55 AM
RotiEatter's Avatar
Ditto
Default Re: Not boosting over 5 lbs? (JDMH22HATCH)
I dont think it is the vacuum lines because they were fine before. I have the BOV going to where the vacuum source for cruise control should be, and the boost gauge is tap[ed into the fpr line. It worked like this before so I dont think this is the problem. So if i disconnect the vacuum line going to the BOV it will still only boost 5 psi even if it is infact my problem?
Old Jun 17, 2004 | 07:02 AM
DaX's Avatar
DaX
Loved
Community Favorite
Build a vacuum manifold...cheap, and takes away the headaches of teeing everything.
Old Jun 17, 2004 | 07:21 AM
RotiEatter's Avatar
Ditto
Default Re: (DaX)
Are you saying that the vacuum lines are my problem? If they are how come they worked fine before?
Old Jun 17, 2004 | 07:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
You could have boost leaking from a coupler...have you pressure tested your intake tract?
Old Jun 17, 2004 | 08:20 AM
RotiEatter's Avatar
Ditto
Default Re: (DaX)
I checked the couplers and they looked fine. I haven't done a pressure test. I just searched on a pressure tester to see how to make one. Didn't fine much info except to use a bike pump with a gauge on it. Anyone have an info on them?
Old Jun 17, 2004 | 08:44 AM
Default Re: (RotiEatter)
Is it going over 5 lbs and then dropping off to 5? Or is it just going up to 5 psi and staying there?
Old Jun 17, 2004 | 08:58 AM
RotiEatter's Avatar
Ditto
It is just going up to 5 and staying there.
Old Jun 17, 2004 | 09:23 AM
skierGT's Avatar
id say sumthings wrong with your wastegate if it levels off at 5psi all the time.
check ur vac lines and spring to the waste gate
someone correct me if im wrong. just a guess
&lt;edit&gt; could be the MBC too.
Old Jun 17, 2004 | 09:58 AM
Default Re: (skierGT)
i don't think its the wastegate, but I do think it has to do with vacuum lines. I had a similar problem, except I was stuck at 3 lbs. Have you tried adjusting your bov out a little bit? Which port are you using on it as well? I would definitely try using a vacuum manifold, helped me a bunch
Old Jun 17, 2004 | 02:11 PM
71 mgb's Avatar
Default Re: (JDMH22HATCH)
bump.. i got a simular problem
Old Jun 17, 2004 | 08:53 PM
RotiEatter's Avatar
Ditto
bump for the late night crew
Old Jun 17, 2004 | 08:55 PM
RotiEatter's Avatar
Ditto
How can it be my vaccum lines if the all worked properly before? They are all in good condition.
I backed the BOV bolt a little bit, but not a lot. Before it was all the way tight and it was fine at 10 psi.
Old Jun 18, 2004 | 01:34 PM
RotiEatter's Avatar
Ditto
Old Jun 18, 2004 | 07:42 PM
RotiEatter's Avatar
Ditto
b18vtec
Mar 4, 2009 10:17 AM
Nextelbuddy
Jun 12, 2004 06:39 PM
RotiEatter
Jun 5, 2004 10:00 AM
Pat
Mar 22, 2004 07:17 PM
PUREVIL
May 20, 2003 09:13 PM
