Is this normal?
Ok, I installed a greddy turbo kit on my d16z6 this was about two months ago. Well I just removed the the filter on the intake side of the turbo to check for oil or anything werid, and I cam accross a small amount of something that felt like oil but did not smell like oil at all. Could this just be something from breaking the turbo in? And could it be caused by the turbo seals breaking in seeing how my turbo was brand new? Thanks!
It was right after where the intake connects to the turbo. I have read some posts where people say it is normal. But I want other point of views.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb »</TD></TR><TR><TD CLASS="quote">I have read some posts where people say it is normal.</TD></TR></TABLE>
That is correct
If you have the port off the valve cover taped into the air inlet pipe than you proly just pulling oil vapors from the crankcase called blowbye. I highly recomend investing in an after market catch can system to elimate this.
How much U boostin? Could you post us a pic?
That is correct
If you have the port off the valve cover taped into the air inlet pipe than you proly just pulling oil vapors from the crankcase called blowbye. I highly recomend investing in an after market catch can system to elimate this.How much U boostin? Could you post us a pic?
