Is this normal?
Old Jun 7, 2004 | 04:07 PM
tolowhb's Avatar
Default Is this normal?
Ok, I installed a greddy turbo kit on my d16z6 this was about two months ago. Well I just removed the the filter on the intake side of the turbo to check for oil or anything werid, and I cam accross a small amount of something that felt like oil but did not smell like oil at all. Could this just be something from breaking the turbo in? And could it be caused by the turbo seals breaking in seeing how my turbo was brand new? Thanks!
Old Jun 7, 2004 | 04:22 PM
tolowhb's Avatar
Default Re: Is this normal? (tolowhb)
Oh and the intake for the turbo has a hose ran to it from the valve cover, this would probably leave some oil near the turbo huh?
2000GSRT's Avatar
What type of filter are you running? It could just be the oil they use on the air filter that has collected a lot of dirt and grime.
Old Jun 7, 2004 | 04:28 PM
tolowhb's Avatar
Default Re: Is this normal? (2000GSRT)
I am using the one that came with the greddy kit, looks like a cheap foam filter.
Old Jun 7, 2004 | 04:46 PM
tolowhb's Avatar
help
Old Jun 7, 2004 | 04:56 PM
2000GSRT's Avatar
did you find the oil in the piping or on the filter?
Old Jun 7, 2004 | 05:03 PM
tolowhb's Avatar
It was right after where the intake connects to the turbo. I have read some posts where people say it is normal. But I want other point of views.
Old Jun 7, 2004 | 06:02 PM
tolowhb's Avatar
Can anyone else ease my mind?
Old Jun 8, 2004 | 03:15 AM
tolowhb's Avatar
bump
Old Jun 8, 2004 | 05:36 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb &raquo;</TD></TR><TR><TD CLASS="quote">I have read some posts where people say it is normal.</TD></TR></TABLE>
That is correct If you have the port off the valve cover taped into the air inlet pipe than you proly just pulling oil vapors from the crankcase called blowbye. I highly recomend investing in an after market catch can system to elimate this.
How much U boostin? Could you post us a pic?
Old Jun 8, 2004 | 05:57 AM
FredoSP's Avatar
hows your compression doing?
EG Boostin
Feb 13, 2007 07:51 AM
HighRevn
Oct 19, 2006 04:43 PM
mrbsponge
Jun 20, 2005 11:22 AM
TURBODC4TEG
Aug 21, 2004 09:05 AM
