no power?
Old Jun 20, 2006 | 06:54 PM
commotion's Avatar
Default no power?
im running a d16z6 with 15g greddy turbo aem fiile rail fuel pressure reg. when i go it takes me like 10 seconds to rev my engine any. and some times when i go i can floor it and go like 7 miles an hour( while this is happing my engine isnt reved high, so dont say it is my tranny )
Old Jun 20, 2006 | 07:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: no power? (commotion)
what are you using for management? what do the plugs look like?
Old Jun 20, 2006 | 07:21 PM
commotion's Avatar
Default Re: no power? (boostedcivicsir)
well i had a vortec fmu but it ran like **** with it on,,, and i have bigger injectors so i was told it was ok to take it off, also i have a missing link maybe can someone post pictures of how the vac lines are suppost to be ran? btw i bought this car like this,,,
Old Jun 20, 2006 | 07:22 PM
commotion's Avatar
oh ill check tth plugs tomarrow whats the gap suppost to be?
Old Jun 21, 2006 | 02:20 AM
commotion's Avatar
bump
Old Jun 21, 2006 | 04:28 AM
oscarmayer's Avatar
go to greddy's website and download the manual for the turbo kit. go over it 1 step at a time. most likley something was done wrong.
also another possibility and not a good one is the motor is blown. the runglands can be bad and holes in the pistons. have a compression and leak down test done on each cyclinder.
Old Jun 21, 2006 | 12:31 PM
commotion's Avatar
Default Re: (oscarmayer)
i did a compression test and it did.
cyc 1 137
cyc 2 155
cyc 3 145
cyc 4 160
how to i proform a leak test? or do i have to take it to a shop?
Old Jun 21, 2006 | 09:27 PM
96 GSR-T's Avatar
Default Re: (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">i did a compression test and it did.
cyc 1 137
cyc 2 155
cyc 3 145
cyc 4 160
how to i proform a leak test? or do i have to take it to a shop?</TD></TR></TABLE>
Not good ^^^^^
Old Jun 22, 2006 | 03:27 AM
oscarmayer's Avatar
those are VERY bad numbers. looks like the motor is fried. your probelby getting so much leakage and blow by the motor is workign against itself due to overpressure of the crank case.
you need to either rebuild it, or get another good motor to repalce it with. there's no way around it. sorry man. your sol.
With the compression test being so low, there's no nead for a leak down.
Old Jun 22, 2006 | 12:59 PM
commotion's Avatar
wow are u kidding? my ratio is 9.2:1 and the guy that did the test said mine was fine he said around 160 is really good. see what my problem is say i get in my car it will run fine.... but if i park it and let it idle and then try to run it. i have zero power like if i floor the gas and sit there for 30 seconds at 300-400 rpms then it will kick in what do u think it is? still the motor?
Old Jun 22, 2006 | 01:12 PM
96 GSR-T's Avatar
Like I said earlier, I am at a high 8 to a low 9:1 and I am around 190-200.
Old Jun 22, 2006 | 02:46 PM
commotion's Avatar
Default Re: (96 GSR-T)
is that with a stock d16z6?
Old Jun 22, 2006 | 05:18 PM
commotion's Avatar
Default i think i fixed it maybe?
hey guys i got my car to run like a champ only thing is i am 32 degrees before TDC is there any reason this could be... my father said that the timing belt might be on wrong.
please reply back with your thoughts..
Old Jun 22, 2006 | 06:52 PM
commotion's Avatar
bump
Old Jun 23, 2006 | 01:28 AM
commotion's Avatar
bump anyone know why i have to have my dizzys bolts out of the holes to run right??
Old Jun 25, 2006 | 12:24 PM
commotion's Avatar
bump
EGdope
Sep 24, 2012 10:02 AM
Akalima
Sep 7, 2006 07:57 PM
f150harleytruck7
Feb 6, 2006 09:33 AM
Gs-R_turbo
Dec 6, 2004 08:16 AM
turbolude92
Jan 15, 2004 06:13 PM
