In line pump or in tank
Old Sep 5, 2002 | 10:29 AM
deacs's Avatar
Default In line pump or in tank
which type of pump should i use in my 1993 civic D16Z6 tyrbo?? i have a vortech 12:1 FMU, FMIC, stock injectors so do i want a 255plh in tank or a inline????? im very confused about this. please help
paul
Old Sep 5, 2002 | 10:33 AM
ELUD THS's Avatar
New User
Default Re: In line pump or in tank (deacs)
depends on what kind of numbers you wnat to be pushing out, if you have an avcr , etc etc and pushing more then 10 psi, i say intank,. but if your runing stock injector and a 12;1 FMU and wont be boostingmuhc, i say inline.
Old Sep 5, 2002 | 10:34 AM
CzanSOHC's Avatar
FMU's need alot fuel pressure...so I believe hat the inline would suit you better w/ your FMU.
Old Sep 5, 2002 | 11:57 AM
TurboIntegra's Avatar
Default Re: In line pump or in tank (ELUD THS)
You are TOTALLY WRONG. PLEASE DO NOT GIVE OUT FALSE INFORMATION.
It is the exact opposite. If you want to be safe with an 12:1 FMU, you MUST HAVE AN INLINE PUMP. An Intank pump can not support the high fuel pressures of the 12:1 FMU.
Please do NOT post if you do not know what you are talking about.
Old Sep 5, 2002 | 12:48 PM
deacs's Avatar
Default Re: In line pump or in tank (TurboIntegra)
ok so lets say i get an inline pump to use with my 12:1 FMU, what sort of boost pressure can i run and what power should i expect from this setup on a D16Z6??
ALSO where can i purchase one of these inline pumps and what spec does it need to be???? Im in the UK so i need to buy from a company that will ship to the UK?? please help cos no one in the UK knows anything about TURBO hondas.
thanks
Paul
Old Sep 5, 2002 | 12:53 PM
rjardy's Avatar
YEAH, an FMU, in order to opperate correctly does need allot of pressure, more than that of what an intank can handle.
Rob
Old Sep 5, 2002 | 01:05 PM
deacs's Avatar
Default Re: In line pump or in tank (rjardy)
thanks
Paul
Old Sep 5, 2002 | 01:06 PM
Etylorcen's Avatar
Why does this topic always come up? Try a search.
Old Sep 5, 2002 | 01:08 PM
deacs's Avatar
Default Re: In line pump or in tank (Etylorcen)
tried it cant find exactly what im after, i need the pump spec and a supplier who will ship to the UK!!! also i need to know what power and boost i can run with a 12:1 FMU and in line pump
How comes the apexi kit comes with an FMU and IN TANK pump???
paul
Old Sep 5, 2002 | 01:14 PM
ekb18c's Avatar
And the debate continues agian.........
Old Sep 5, 2002 | 02:14 PM
rjardy's Avatar
in order to keep us on our toes this is a very difucult question
(but if you have been here for over 3 months its probably imbedded into your brain)
Rob
YellowPhoenix095
May 14, 2007 06:30 AM
SIK IN DA HED
Nov 18, 2003 10:30 AM
SIK IN DA HED
Nov 13, 2003 08:53 AM
_Endless_
Sep 2, 2002 01:28 AM
