stop spooling after i hit full boost help
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
wasup guy i have a problem here i was driving right on 2nd gear then press the gas then i hit full boost then it stop pulling then i get cel help
Flux capaciter needs a recharge.
Seriously though... you need to provide a weeeee bit more info if anyone is even going to be able to remotely help you.
my guess is a boost leak or check that your boost controller is connected correctly. another idea may be that your BOV or if your running with a wastegate that the gaskets have blown......not positive what but those are easy place to start
B A N N E D
is like more fuel but no air coming in the intake mani. i think its my bov
last i check my bov im pushing the valve up and it is stiff and last night i check its loosebu t i dint know
B A N N E D
i dont have boost controller and my wastegate is brand new tial wastegate my bov is xs rfl if that matter
B A N N E D
not installed yet but the last time i step on it fine it does do that but not it does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">im confused</TD></TR></TABLE>
Exactly why I asked for more info.
You need to tell us your setup... parts included.. especially fuel/tuning equipment. Also what map sensor, what boost PSI etc....
B A N N E D
ok here
b16a stock block
type-r cams
supertech valve springs and retainers
skunk 2 manifold
t3/t4 to4e turbo 50 cold 63 hotside
-3an feedline -8 return
2.5 dp
equal length ram manifold
tial 38mm wastegate .6 bar spring
rfl bov
vafc2
missing link
no fuel management at all yet im just waiting for my injector 440cc to come so i can put
255 walbro intank fuel pump gph
fuel rail
uberdata po5 ecu basemap
and the 440cc its coming
lmk thanks for all the inpput
b16a stock block
type-r cams
skunk 2 manifold
2.5 dp
rfl bov
vafc2
missing link
fuel rail
Is the uberdata basemap setup properly for normal sized injectors? or for the 440s already...
Does the basemap even have a boost side to it? since you don't have injectors... hopefully the basemapper knew better than to give you a way to boost.
You should NOT be trying to boost yet
. Get the injectors in first, then pull the missing link and then tune... also, go ahead and pull out that vafc2... its useless except for the blinky lights.
B A N N E D
basemap for 440cc and i havent put them on yet
now im goanna stay out of boost till i get my injector
and im goanna try to take off my vafc2 and sell it
thanks splittime
more input
thanks splittime
more input
The basemap is for the 440s eh, then you are running the stock 240cc injectors.... so basically you are driving the car extremely LEAN. Stop driving it now, or get a normal map to drive on until you get the 440s.
That hesitation you were getting was either the map seeing boost (which i doubt with missing link) but more likely... the car running so lean it hesistates like a fuel cut.
it could be your missing link... that happened to me before i switched to my 3bar
sometimes ill drive and hit full boost and then CEL comes on and then it feels real sluggish...
i junped the light and it said map... so i switched out to another missing link and no more...
pulled fine...
jump the CEL
pulled fine...
jump the CEL
