NO boost?
Old Jul 19, 2005 | 03:52 PM
buddha1320's Avatar
Default NO boost?
i just installed my boost gauge and nothing comes up . also my blow off valve makes no noise it opens up but has no sound its a greddy type s blow off valve and ideas on what might be wrong i already checked alll the hoses and they are all nice and tight thanks in advance
Old Jul 19, 2005 | 04:29 PM
bubs's Avatar
Default Re: NO boost? (buddha1320)
Does it feel like you're making boost? Does the car feel faster and do you hear the turbo spooling?
Is your wastegate hooked up correctly? Need some more info on what's going on.
Old Jul 19, 2005 | 04:34 PM
bnut510's Avatar
got a boost leak somewhere... or is your turbo even spooling? i had a similar problem before, check the turbo to make sure it spins... if so... then recheck all the piping.. it sounds like a boost leak tho
Old Jul 19, 2005 | 04:45 PM
buddha1320's Avatar
Default Re: NO boost? (bubs)
yes the car feels much faster and i do hear the turbo spooling up ... about the wastegate i heard it opening and closing when i had no bov then i installed the bov i no longer heard it how tight should it be because right now its on pretty tight its an internal wastgate by the way
Old Jul 19, 2005 | 05:18 PM
bubs's Avatar
I would guess that something's up with your blow off valve - almost like it's not closing and venting off some of your boost. Also, what are you using for vac. sources on your boost gauge and bov?
Old Jul 19, 2005 | 05:23 PM
buddha1320's Avatar
i have the boost gauge teed between the wastegate and turbo and the bov is coming off the fpr
Old Jul 20, 2005 | 06:38 AM
buddha1320's Avatar
still nothin
Old Jul 20, 2005 | 06:42 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buddha1320 &raquo;</TD></TR><TR><TD CLASS="quote">i have the boost gauge teed between the wastegate and turbo and the bov is coming off the fpr</TD></TR></TABLE>
Dont tee your boost gauge to the wastegate actuator line. In fact I dont think you ever want to tee anything off of the wastegate line (other then a boost controller). Tee the BOV and boost gauge to a vacuum source on the IM. I think you'd get a more accurate boost and vacuum reading if you tap the gauge on the IM after the TB.
Old Jul 20, 2005 | 08:50 AM
buddha1320's Avatar
Default Re: NO boost? (BlueShadow)
so then i tee both the bov and boost gauge to the IM the only line i see is on top where the fpr is on is there another line i can tap into its a 96 ls motor
Old Jul 20, 2005 | 08:58 AM
BlueShadow's Avatar
I've heard people say that it is also a bad idea to tap two items off of the FPR. You could try tapping off of the brake boost line, but it's a big hose. You could also run a vacuum manifold and just run all your vacuum sources off of that.
Old Jul 20, 2005 | 09:03 AM
lucidvtec's Avatar
run a vacuum mani...only like 40bux from mccar
TravisBiggie
Mar 1, 2013 05:59 PM
RFd15bhatch
May 24, 2005 12:27 PM
apexrift
Mar 1, 2005 12:59 PM
pipes
Feb 19, 2004 05:21 PM
yorktonite
Aug 23, 2002 08:33 AM
