Installing Zex Dry nitrous system (Help)
Old Jun 2, 2008 | 11:02 AM
EfSedanLove's Avatar
Default Installing Zex Dry nitrous system (Help)
sorry if this is in the wrong area but.... my question is, is phearable capable of tuning for nitrous? my setup is a b18b1, intake, full exhaust, and prechipped ecu. planning on installing a Zex Dry nitrous system. how much do i retard the timing and im running oem honda sparkplugs. im also picking up a fuel pressure regulator because when i took it to the dyno i was running a bit lean. and im running a apexi neo if that will do anything. Thanks
Old Jun 2, 2008 | 12:23 PM
nsxmatt's Avatar
Default Re: Installing Zex Dry nitrous system (EfSedanLove)
Your questions should be answered in the instructions of the kit. Retard the timing 2 degrees and run a colder ngk plug I believe based on a 50 shot. If running a 75 you should upgrade the fuel pump and run a colder plug and less timing.
Old Jun 2, 2008 | 12:48 PM
Default Re: Installing Zex Dry nitrous system (nsxmatt)
its used : ( but im getting it for cheap though : ). im going to get my fuel stable since its sorta leans out. fuel pressure regulator a easy fix? whats the stock fuel pressure suppose to be at? btw the setup is in a 94 civic lx with a b18b1 : )
Old Jun 2, 2008 | 06:29 PM
bump
Old Jun 3, 2008 | 04:37 AM
aladdin's Avatar
You don't need to tune a zex dry kit as long as you stick to the specified jetting. Make sure all injectors are in good health. I would replace the fuel filter and also to be safe replace the fuel pump with an in tank walbro 255. You can download the instruction from zex.com
nitroaccord105
Jul 18, 2007 12:32 PM
JDMDC4life
Oct 12, 2006 02:18 PM
DC5ftmfw
Sep 15, 2006 03:34 PM
msbhvn_DC2
Feb 16, 2006 12:41 PM
YourHondaSucks
Feb 8, 2004 03:30 AM
