nitrous question
Old Jan 30, 2005 | 06:41 PM
BlackOnBlackTeggie's Avatar
Default nitrous question
i have a Jdm Gsr from hmotorsonline, (10:6.1 compression). and i have a NX stage one wet kit, i have the 50 shot jets in right now, i have intake, header, exhaust skunk2 intake mani. fpr at 45psi, the bad thing is i have a chipped Ecu. will a 50 shot be safe even with the ecu? sprayed it like 2 times and ran great no detionation or anything. stock ngk-r plugs. thanks
Old Jan 30, 2005 | 06:48 PM
beepy's Avatar
Default Re: nitrous question (BlackOnBlackTeg)
Why would a chipped ECU have anything to do with it?
Old Jan 30, 2005 | 08:12 PM
Aggressive Racing's Avatar
Default Re: nitrous question (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Why would a chipped ECU have anything to do with it?</TD></TR></TABLE>
Maybe he is a little worried about the advanced timing.
You shouldnt have a problem,but if you want to go with a bigger shot,you might want to retard the timing 2 degrees from the distr.
Old Jan 31, 2005 | 01:08 AM
JSpin's Avatar
Default Re: nitrous question (aggressivemotorsports)
you need to get the specifics of that "chip" before you do anything.
Old Jan 31, 2005 | 03:44 AM
Default Re: nitrous question (JSpin)
its a "mugen" chip , says it advanced the timing and differant fuel maps. it runs real good on the 50 shot but i might want to go up to a 75,
Old Jan 31, 2005 | 07:04 AM
ham's Avatar
ham
50 shot is really nothing. i ran a 55 shot on my b16/typeR with a spoon all motor ECU. i cant say its gonna be fine but the right thing to do is get the right chip.
Old Jan 31, 2005 | 03:29 PM
Default Re: nitrous question (ham)
anyone know what chip is good for nitrous?
Old Jan 31, 2005 | 05:59 PM
97hb's Avatar
Becareful, incorrect timing and boost can kill a motor in seconds.
Old Feb 1, 2005 | 08:02 PM
nuclearhappines's Avatar
Default Re: nitrous question (97hb)
there are only two ways to do this
1- figure out how much the chip advances over stock, and pull that much timing out at the dist+ whatever is recommended for that size shot when you want to spray
2- Get an EGT guage... and work your shot size up and monitor your EGT's ... if they start to climb then more octane, less nitrous, richer mixture or retarded timing.... if you're EGT's are safe and your a/f is good then you have some head room
other than that you will never get a real answer to your question.
Old Feb 1, 2005 | 10:10 PM
wolfsburg2's Avatar
if it were me i'd just get a stock ecu. the na gains from the ecu are def not worth the possibility of a popped motor imo. advanced timing+nitrous is just not smart, why risk it.
OrangeTeggy
Aug 2, 2010 12:12 PM
fatpride111
Sep 13, 2007 02:56 PM
teefunk01
Sep 6, 2005 05:26 PM
JAYGSR
Jun 8, 2004 01:49 PM
dvp95
Aug 20, 2003 05:31 AM
