newest uberdata released
Old Nov 23, 2003 | 01:20 PM
  #951
raene's Avatar
Default Re: (DA-MAX)
Thanks toxicshit - I actually have a hexeditor and I've already done the edits, but thanks anyway The ECU is in my car and the OBD1 conversion works... sort of. I'm getting a code 9 (CYP) so I messed up somewhere I'm not sure if that's preventing other codes from showing. I'm using an auto chipped USDM P28 for the computer, PA enabled, ELD enabled, speed limiter at max, knock disabled, O2 heater disabled (only using a 1-wire) and like I said... only that one code, for now.
Old Nov 23, 2003 | 01:29 PM
  #952
traction issuez's Avatar
sorry for not reading 32 pages, but i got myself a p28 but it's from an AUTO, can i use it for MANUAL tranny after i chip it?
  #953
swlabhot's Avatar
Default Re: (toxicshit)
Thx for clearing that up Toxicshit. Why would you want either of these two disabled? I what situation would you want to disable these sensors?
Old Nov 23, 2003 | 02:03 PM
  #954
raene's Avatar
Default Re: (boostedrotary)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedrotary &raquo;</TD></TR><TR><TD CLASS="quote">sorry for not reading 32 pages, but i got myself a p28 but it's from an AUTO, can i use it for MANUAL tranny after i chip it?</TD></TR></TABLE>
Did you read the post directly above yours, that I made, when I clearly stated I used an auto P28 ECU? I can understand not wanting to read 32 pages, but it's the last post you should've looked at.
Old Nov 23, 2003 | 02:04 PM
  #955
raene's Avatar
Default Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Thx for clearing that up Toxicshit. Why would you want either of these two disabled? I what situation would you want to disable these sensors?</TD></TR></TABLE>
You would disable the sensors if they don't exist on your ECU or setup and they're causing problems with check-engine lights. I disable knock since I don't have a knock board on my ECU. I have the PA and ELD so I left those enabled. Just pick and choose what you've got.
Old Nov 23, 2003 | 04:07 PM
  #956
Default Re: (raene)
cool, alrighty, so there isn't anything i need to change right? i'm going radio shack after church, to get the 1/4 watt 1.0k resistor, 2 0.1uF ceramic Disc Capacitors, one 74hc373ic, and a 28 pin socket. Then bring it to school tomarrow so i can solder it in.
Old Nov 23, 2003 | 06:27 PM
  #957
hulkhb's Avatar
Did i miss the scroll version ? Has it been made.released yet ? I still need it so i can use it on my laptop.
TIA
Old Nov 23, 2003 | 06:31 PM
  #958
rjardy's Avatar
Default Re: (hulkhb)
well the 3 bar has scroll bars but i cant seem to get them to work.
I just broke down and bought a new laptop
Rob
Old Nov 23, 2003 | 06:36 PM
  #959
crap, i went to radioshack they only had 1k ohm resistors (1/4 watt) and 0.1uF ceramic Disc capacitors. That's it! i have to special order the rest, so i'm just going order online from jdr.com
and jdr.com has
74HC373 TRI-STATE OCTAL D LATCH 20P $.39
is this what i should order?
Old Nov 23, 2003 | 06:37 PM
  #960
hulkhb's Avatar
Default Re: (rjardy)
well i paid for the 3bar about 2 months ago and still got nothing. so thats really not working for me. and i dont have the extra cash to blow on a new LT, like some rich folk do
Old Nov 23, 2003 | 08:14 PM
  #961
b18c_00hatch's Avatar
hi everyone, ok i've spent this past week reading this entire post and most of the links from it. i know its old but better late than never right. i gotta say this is the coolest thing i've ever found on the net and u know theres alot of crap on the net! well im definite going to use this program to tune my ecu but before i start buying i just want to run my shopping list through u guys and get an okay from the pro's.
1 Batronix Eprom Programmer from here (http://www.progshop.com/shop/programmer/index.shtml) assembled 98$
2 1/4 Watt 1.0k resistor from radioshack
3 two 0.1uF Ceramic Disc capacitors from radioshack
4 one 74HC373 IC from radioshack
5 28-pin 29c256 eprom (i think im going to get like 3) here http://www.moates.net/gmecm/hworder.html
6 Zif socket from here http://www.moates.net/gmecm/hworder.html ( can some1 tell me which one will fit in a p72 without getting in the way of the atompheric pressure thing?)
Is this pretty much it? am i missing anything? another question a i plan on putting a b16a head on my gsr and put all type r interals inside will the p72 run this setup without problems? i think so but just asking. thanks sorry for a newbie post
Old Nov 23, 2003 | 08:26 PM
  #962
DA-MAX's Avatar
Default Re: (b18c_00hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c_00hatch &raquo;</TD></TR><TR><TD CLASS="quote">
just trim off the excees on the end of the zif socket with a dremel or knife. when the zif is in front of you, you'll obviously see how much needs to be trimmed...after that it'll slip right in there no problem. I have a pic if you need it.
Old Nov 23, 2003 | 08:38 PM
  #963
BSeriesTurbo's Avatar
so I guess we still have no word on the p13 bins? I plan on running a p28 w/ a modified p72 code...but I'd like to be able to copy the fuel/ignition tables over from a p13..
Old Nov 23, 2003 | 08:46 PM
  #964
pbomers's Avatar
Default Re: (BSeriesTurbo)
so does the ERM p28 bin have the knock sensor disabled since it's based off the p75/72 code? i would just go in with a hex editor and check, but i'm not the best with hex editors.
thanks and keep up the good work guys!!!
-Paul
Old Nov 23, 2003 | 09:06 PM
  #965
raene's Avatar
Default Re: (TinyCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TinyCRX &raquo;</TD></TR><TR><TD CLASS="quote">so does the ERM p28 bin have the knock sensor disabled since it's based off the p75/72 code? i would just go in with a hex editor and check, but i'm not the best with hex editors.
-Paul</TD></TR></TABLE>
No it doesn't. You need to change it yourself If you email me at raeneshadowAThotmailDOTcom I will send you an edited P28 baseline bin with the knock sensor disabled... but I'd rather you open up the hexeditor and do it yourself. It's easier than you think! I used a program called Hexedit. Addresses are on the left, and the central numbers are in the right. So if you're looking for 24a3, look for 24a0, then count 0-1-2-3 over and click that address. There will be two characters there. Change them to match what you want. For knock sensor, just look for the knock sensor address, click the cell, type in the disable code (I can't remember if it's FF or 00) and save the file. Done!
Old Nov 24, 2003 | 03:06 AM
  #966
toxicshit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Thx for clearing that up Toxicshit. Why would you want either of these two disabled? I what situation would you want to disable these sensors?</TD></TR></TABLE> Im in Europe our engines dont have those sensors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Thanks toxicshit - I actually have a hexeditor and I've already done the edits, but thanks anyway </TD></TR></TABLE>No THNX
Old Nov 24, 2003 | 04:46 AM
  #967
Quade's Avatar
Default Code
Why is it Spoon and Skunk can make chips for the P13 and we can't use the P13 with uberdata? Just wondering.
Old Nov 24, 2003 | 06:40 AM
  #968
toxicshit's Avatar
Default Re: Code (Quade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">Why is it Spoon and Skunk can make chips for the P13 and we can't use the P13 with uberdata? Just wondering.</TD></TR></TABLE>
Because ubderdata is made for p72 base programs only. and if you have a p28 or a p13 you must use a p72 base with the p13 or p28 fule /ignition tables etc....
Old Nov 24, 2003 | 06:58 AM
  #969
Quade's Avatar
Default Re: Code (toxicshit)
IC. ty.
Old Nov 24, 2003 | 01:33 PM
  #970
falcongsr's Avatar
What is this crap?
update, drove my car to work today
outside temp 32 degrees. car temp 32 degrees. started right up. cold idle wandered a bit around 1500rpm. but it was perfectly drivable. car warmed up and boosted fine.
sometimes on cold start, my car starts right up but the idle doesnt catch and it shuts right off. only done it like 10% of the time. restart and its fine. i think its the fuel trim but i have no way of datalogging that yet. anyone experience this?
one time it did it hot and i had to hold the throttle to get it to idle, it was really rich i think, and then the fuel trim leaned it out and all was well. really odd.
other than that, its perfect.
Old Nov 24, 2003 | 01:38 PM
  #971
raene's Avatar
Default Re: Code (falconGSR)
Sometimes my fuel pump won't turn on when I start it - perhaps that's your problem. When the fuel pressure drops it would die down pretty fast; if you turn it to 'off' then 'on' again it would re-prime the pump. I have a 190lph, no interior and no sound deadening so I can really hear it clearly.
My cold idle is also very strange and wandering. Very uneven, it misfires and pops a lot and it runs very rich.
I've been fiddling with the idle percentages and it's idling much better than it did before (when hot), but it's still very uneven. I also drove to work today, actually it drove stoich most of the time but I need to fiddle with the low-throttle parts of the map I took 10% out of everythign but the leftmost 2 columns and 5% out of everything in the left 2 columns but the top 2 cells. I'm going to take another 5% out and see how that goes
The main thing I'm worrying about is when I put it at more than 50% throttle the car bogs out and tries to die... it feels like it's hitting a rev limiter, a fuel cut, or just plain running out of fuel. The cheap air/fuel gauge goes to stoich when this happens. I was thinking it might be a bad wire somewhere in my conversion harness... anyone else have this happen?
BTW how can I contact Blake? I'd like to donate for his good work here and I'd like to get the 3bar Uberdata... also wondering what the release date for the next version of Uberdata is.
Modified by raene at 3:30 PM 11/24/2003
Old Nov 24, 2003 | 03:54 PM
  #972
T-RO's Avatar
I have some 28 pin ZIF sockets for sale. I can trim them before shipping or you can do it. Email me if interested (I dont think new users can IM) tro@mpinet.net
Old Nov 24, 2003 | 05:18 PM
  #973
PHiZ's Avatar
Default Re: (T-RO)
http://crimethink.org/images/P28_with_ZIF.jpg
I don't know what everyone is talking about...?
-PHiZ
Old Nov 24, 2003 | 06:30 PM
  #974
rjardy's Avatar
Default Re: (PHiZ)
The arias ZIF's need to be trimmed. Its not that bad though, just a few seconds with the dremel and it takes care of it nicely. What ZIF is that PHiZ?
ROB
Old Nov 24, 2003 | 07:59 PM
  #975
PHiZ's Avatar
It's just a regular full size ZIF.
http://www.jameco.com/cgi-bin/...5;759;
What I would like to share though, is that my Romulator does NOT like the Aries low profile ZIFs.
-PHiZ
