new version of uberdata
Old Dec 17, 2003 | 04:46 AM
  #301
toxicshit's Avatar
Default Re: (Buraku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Hmmmm, I will write a nitrous/meth/propane injection script tommorow.</TD></TR></TABLE>
Verry nice idea Buraku.
page 11 owned :D
Old Dec 17, 2003 | 05:27 AM
  #302
VTC_CiViC's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
one more thing, i havn't really run uberdata much but i ran it all day today and noticed that my injectors seems to shut off a little prematurely and also they came back on a little late. this was causing a little jerking when i am just barely giving it gas. did anyone else notice this?
Modified by ndogg at 3:27 AM 12/17/2003</TD></TR></TABLE>
Hmm.. something the 'hack' is notorious for..
Old Dec 17, 2003 | 06:22 AM
  #303
cornhusker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">
thanks! for excellent service/support!
Old Dec 17, 2003 | 07:38 AM
  #304
GimpyAccord's Avatar
ndogg, the asm is a1kons.. so the same rules apply.
Old Dec 17, 2003 | 08:12 AM
  #305
raene's Avatar
Default Re: (ndogg)
one more thing, i havn't really run uberdata much but i ran it all day today and noticed that my injectors seems to shut off a little prematurely and also they came back on a little late. this was causing a little jerking when i am just barely giving it gas. did anyone else notice this?</TD></TR></TABLE>
I always figured that was due to my TPS being miscalibrated, haven't gotten around to fixing it yet I'm definitely experiencing the same thing, though. Anybody else have this problem?
At the track you should probably be dumping the clutch in 2nd gear w/ the slicks in the burnout box. I don't think it's a problem since as was said FTL will shut off when it sees some speed. It's only limiting how high you can dump the clutch at, and if you're sitting in the waterbox the slicks will have almost no traction anyway so you don't need to dump it that high.
Old Dec 17, 2003 | 09:58 AM
  #306
Default Re: (raene)
Is this jerking a TPS tip-in/out issue?
Old Dec 17, 2003 | 10:22 AM
  #307
raene's Avatar
Default Re: (GimpyAccord)
Only going from zero or near-zero throttle. It drives perfectly smoothly elsewhere in the throttle range. I've been fiddling my TPS from before I installed Uberdata + converted to OBDI - similar problem with my PR3 on OBD0 - so I assumed it was leftover problems with the setup that I need to adjust the TPS for (again). My multimeter is inaccurate
Old Dec 17, 2003 | 01:31 PM
  #308
non-VTEC's Avatar
i downloaded the idle.als.txt (idle adjustment?) and put it in the ubderdata directory but nothing comes up in uberdata when i open my P75 bin.........
is it working for everyone esle?
Old Dec 17, 2003 | 01:41 PM
  #309
Default Re: (non-VTEC)
I just tested it on StockLS.bin, its working.
Guys, make SURE you're not using some old crusty ERM or Uberdata bin. Back in the day uberteg moved **** around and bla bla... things are a lot different now.
Old Dec 17, 2003 | 01:45 PM
  #310
non-VTEC's Avatar
it would be under misc tab right?
it's not showing up for me........dont know why........
Old Dec 17, 2003 | 02:00 PM
  #311
no .. its under the Rev limit tab... along with all the other RPM/rev related stuff.
Old Dec 17, 2003 | 02:24 PM
  #312
non-VTEC's Avatar
ahh i found the problem. i had myftl.als.txt and myftl.asm.txt files in the same directory and it wasnt displaying the idle adjustment because the FTL/FTS settings were there.......
it's all good now.....
Old Dec 17, 2003 | 04:51 PM
  #313
B94Cast's Avatar
How about a script that will disable closed loop at a certain pressure?
Old Dec 17, 2003 | 05:33 PM
  #314
VTC_CiViC's Avatar
Default Re: (B94Cast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B94Cast &raquo;</TD></TR><TR><TD CLASS="quote">
How about a script that will disable closed loop at a certain pressure?</TD></TR></TABLE>
I was just thinking about that, Ubderdata keeps closed loop without the option to disable it ala Hondata right?
Old Dec 17, 2003 | 05:59 PM
  #315
B94Cast's Avatar
Default Re: (VTC_CiViC)
You are correct sir. I would really love the ability to control this!
Old Dec 17, 2003 | 06:20 PM
  #316
Quade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">I posted 1.62 @ http://www.ecimulti.org/uberdata/downloads/app</TD></TR></TABLE>
I just tried downloading ver 1.62 from this same site at home and only got the .exe and autoexec file. Strange. It work perfect at the office.
Old Dec 17, 2003 | 07:01 PM
  #317
VTC_CiViC's Avatar
Default Re: (Quade)
Question regarding the IAB input. I've physicaly disabled the IAB's (using P28 right now so they're open all the time), so by leaving the IAB at 0, will it give me a CEL thinking the IAB's won't open, or will it operate with the anticipation of the IAB's always being open?
Old Dec 17, 2003 | 09:36 PM
  #318
ndogg's Avatar
ecu doesn't have IAB codes. so it wont matter.
Old Dec 18, 2003 | 04:31 AM
  #319
Quade's Avatar
Baraku, Is ver 1.62 still working from your posted download site? I just tried and expanded the zip but got no scripts with it. Only the .exe and autoexec file. Let me know.
Old Dec 18, 2003 | 04:48 AM
  #320
ndogg's Avatar
Default Re: (Quade)
it works. you need to get the scripts separetly as well as the dll file from another version.
Old Dec 18, 2003 | 05:47 AM
  #321
VTC_CiViC's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">ecu doesn't have IAB codes. so it wont matter.</TD></TR></TABLE>
I never thought of that.. I suppose that means I'd have to run with a disabled KS as well then?
Old Dec 18, 2003 | 07:08 AM
  #322
Unless you have a knock board & sensor, it must be disabled. Otherwise you're in limpz/gimpz mode.. IMMEDIATLY upon turning the key to the on position.
Modified by GimpyAccord at 8:32 AM 12/18/2003
Old Dec 20, 2003 | 07:56 PM
  #323
stizzit's Avatar
Hey guys - Just put an uberdata-chipped eprom in my ecu, and installed 550cc injectors. I scaled the maps according to 240/550+5 = 49% and took her for a drive. She idled high, at 1500, I ALSO have the TPS issue where ifyou just barely tap the throttle its really jerky and such.
My main problem is I can build boost, but as soon as I do the car just holds the RPM and falls on its face. I didn't try much higher, but it did make it to 5psi yet the car didn't accelerate, just sat there and was mad, lol. Any ideas?
At first I was sure it was because of my MAP limiter, so I removed that because I had forgotten to. That really didn't help so I'm not sure where I stand. I've been over and over the maps and they all seem right. Any ideas anyone?
Old Dec 20, 2003 | 08:17 PM
  #324
ndogg's Avatar
Default Re: (stizzit)
whats your A/F? timing?
Old Dec 20, 2003 | 08:22 PM
  #325
stizzit's Avatar
Default Re: (ndogg)
i don't have a wideband so A/F, no idea, I watch my EGT's.
Base Timing is set to 14deg BTDC i believe and 0.9 in the deg to retard per 1lb of boost.
