new track times - *w/vafc hack*
Old Jul 15, 2002 | 03:56 AM
DSF's Avatar
DSF
Default new track times - *w/vafc hack*
Ok, I went to the track last friday to see what my daily driver (88 CRX) would do. I went with full exhaust, full interior, full tank of gas (93/98 octane mix), and 4pt roll bar. Traction was provided by a set of Nitto 555R drag radials. For some reason my boost was flutuating on all of my runs, especially in the lower gears. Normally I run @8-8.5psi. My best run was actually at a measly 7psi . Anyway here are a couple of the times...
run #1
radials @20psi w/moderate 2nd gear burnout
btm @.5*/psi
60' - 2.272
330 - 6.218
1/8 - 9.460
mph - 62.33
1000 - 12.256
1/4 - 14.615
mph - 96.44
...car was still very hot as I had just arrived at the track.
run #4
radials @16psi w/large 2nd gear burnout
btm @0
60' - 2.274
330 - 6.116
1/8 - 9.235
mph - 79.27
1000 - 11.925
1/4 - 14.193
mph - 99.66
set-up rundown...
88 CRX
stock Y7 shortblock
stock A6 top end
DX tranny
centerforce clutch
VAFC hack w/DSM 450s and GS-R fuel pump
MSD BTM
2* retard cam timing
16*BTDC ign. timing (now back up to 18* BTDC)
205/45-15 Nitto drag radials
T-25 turbo
Starion intercooler
This friday....10-12psi
See my resulting boost raising attempts here ...
https://honda-tech.com/zerothread?id=230180
[Modified by DSF, 8:22 AM 7/15/2002]
Old Jul 15, 2002 | 05:15 AM
CovertFI's Avatar
Default Re: new track times - *w/vafc hack* (DSF)
so you had your timing advanced at the dist? and had it retarted at the cam gear? and then had your btm set to .5 per lb of boost. i am almost sure you could of went full stock timing at only 8psi with your 93/98 octane mix. i run full timing at 5psi on just 93 octane. that is a power loss for you.
i have not ran at the track yet, but your run looks good
Old Jul 15, 2002 | 05:39 AM
DSF's Avatar
DSF
Default Re: new track times - *w/vafc hack* (CovertFI)
Yeah, that was kinda confusing. Originally (before the track) my cam gear was at 0, my ign. timing was at 18* and BTM was at .5*. Before going to the track I retarded my cam timing 2* (to help out my top end), hence dropping my ign. timing to 16*, BTM being untouched. I meant to reset my ignition timing at the track, but forgot my timing light. I also meant to try different cam settings, but forgot my allen wrenches. Actually, I forgot all of my tools The first run I just forgot about the BTM, so it remained retarded, but I set it at 0* after that.
This Friday...more boost, more timing, and less fuel
boost fed ls
Apr 4, 2004 10:42 AM
turbob16hatch
Aug 6, 2002 10:00 AM
VTC_CiViC
Dec 4, 2001 02:28 PM
B17aTrbo
Oct 27, 2001 04:44 AM
