need turbo install help FAST!!!!!
hey guys i just got a turbo kit and when i put the manifold and turbo together the oil return is on top??? its a turbonetics t3 t4, is it possible to take it apart and rotate the cartridge? will i hurt anything?
Loosen the bolts that hold both the compressor side and exhuast side and rotate the turbo till your desired angle is reached ..
Remember to not tilt the cartridge too far or you will run into oil problems
There is 6 retaining bolts on the compressor side and 6 on the exhuast side ...
You should see what looks like a plate connecting 3 out of each 6 on both .. Loosen those then you can rotate the housings how you need them
