need suggestions on how much boost to run and how to run it
Old 02-19-2008, 06:41 AM
pbzhb's Avatar
Default need suggestions on how much boost to run and how to run it
I have an ls motor with about 40k on it, running a drag kit. I wanted to know if 10psi was ok to run on this motor currently I am tuned running 8.5. My next question is I have a profec B spec II and hear it has a lot of problems with temperature and its difficutly in setting up so should I just buy a 10psi spring for my waste gate and run that with no boost controller or should I get a manual boost controller and run a 7psi spring and use the mbc to up my boost? Some suggestions please.
Thanks in advance
Old 02-19-2008, 09:34 AM
pbzhb's Avatar
Default Re: need suggestions on how much boost to run and how to run it (pbzhb)
please can i have some suggestions. you guys are all alot brighter than me so your input would be of value.
thanks
Old 02-19-2008, 09:42 AM
DOWNwithHT's Avatar
What size injectors do you have, what are the specs on the turbo, and how is the car tuned? I'm guessing you would be fine at 10psi. As far as boost controllers go, I say forget them and just buy a couple springs to run the different boost settings you want. It might take a little more effort to change a spring, but the reliability is worth it IMO.
Old 02-19-2008, 09:48 AM
dopeem1's Avatar
Default Re: need suggestions on how much boost to run and how to run it (DOWNwithHT)
yeah man i personally dont like the greddy.. but im not ******* it... i would run a 10 psi springs in the gate and tune it that way.. also if your not built i wouldnt suggest 10 psi.. you may pop something but its not a for sure thing...
Old 02-19-2008, 10:21 AM
DOWNwithHT's Avatar
Default Re: need suggestions on how much boost to run and how to run it (dopeem1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dopeem1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah man i personally dont like the greddy.. but im not ******* it... i would run a 10 psi springs in the gate and tune it that way.. also if your not built i wouldnt suggest 10 psi.. you may pop something but its not a for sure thing...</TD></TR></TABLE>
10 psi is fine on LS as long as you have the injectors and tune to back it up. I beat the hell out of my stock 110k mile LS turbo all day with RC 550's tuned on Hondata S300.
Old 02-19-2008, 11:58 AM
pbzhb's Avatar
I am running a t3/t4 .57 trim i believe and .48 hotside not sure though wish i knew how to check. its a turbonetics and was supposedly part of the drag kit. Anyways I have 440s and I used crome to tune it. car runs strong on 8.6 so im assuming the tune is good. Hope this helps.......lets keep the suggestions cominggg
Modified by pbzhb at 4:12 PM 2/19/2008
Old 02-19-2008, 09:14 PM
pbzhb's Avatar
cmon i know you guys have some more suggestions
Old 02-20-2008, 07:53 AM
pbzhb's Avatar
all these views and no suggestions. cmon
integraRS-T
07-08-2007 03:56 PM
freeplay
09-04-2003 06:38 PM
RyanAutry
11-06-2002 07:08 PM
Nikos
07-10-2002 08:46 AM
Coldsi
05-14-2002 01:03 PM
Quick Reply: need suggestions on how much boost to run and how to run it
