need someone to read engine compression results
Old Apr 10, 2005 | 09:20 AM
eag36's Avatar
Default need someone to read engine compression results
Hey guys, i'm lookin for someone who really knows how to read engine compression results to give me a few pointers.
Cylinder: 1 2 3 4
PSI 194 161 141 194
then i added probably a teaspoon of oil to the # 2 & 3 cylinders
PSI - 190 210 -
Also looking into the spark plug holes, numbers 2 and 3 had some carbon deposits, more so than 1 and 4. Especially 3, which i attribute the high pressure after adding the oil. The number 3 spark plug hole is very oily all the up and down the hole. This might have been due to the loose spark plug described later, but the valve cover seal around the #3 hole also looks worn compared to the other 3.
So at first I thought it might've been a head gastet blown between 2 and 3, but when i added the oil the pressure came back up which makes me think rings.
Some info on my car: 98 LS 60k miles, burns 1 qt every 5k. No coolant leaks or at least none noticable. When i bought the car, it was from a saturn dealership and i don't think they really knew how to tune it up. When i went to change the spark plugs to platinums, the #3 cyl was finger loose, more than a full turn out from the head. Also, i was hearing ticking from the engine at idle and pulled the head off and it turns out my tolerances between the cams and cam followers were way high.
Also, I have a turbo kit that i was planning on putting on, but i'd be interested to hear input on that too.
Old Apr 10, 2005 | 10:47 AM
thecorey's Avatar
Default Re: need someone to read engine compression results (eag36)
i would have said blown head gasket between 2 and 3 cylinders, but since the psi shot up with oil added and there are carbon deposits i'm gonna say you need to rebuild the bottom end. If coolant were leaking into 2 & 3 then the cylinders would be clean. Oil in the spark plug hole is just the valve cover gasket - nothing serious.
Old Apr 10, 2005 | 11:02 AM
Finland's Avatar
Be warned, the loose spark plug is an age old trick of scammer car dealerships. Sometimes when a car has ring/headgasket problems, the scammer mechanic will loosen the sparkplug to relieve compression...the problem disappears...until you just found it. I hope this isn't the case, but you'll have to pull the head to see what's going on.
Old Apr 10, 2005 | 11:22 AM
eag36's Avatar
Default Re: (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">Be warned, the loose spark plug is an age old trick of scammer car dealerships.</TD></TR></TABLE>
I bought it from a saturn dealership... so I tend to doubt thats the case, but then again anything's possible.
phaphon
24
Apr 13, 2017 09:00 AM
nengx07
20
Feb 6, 2009 08:10 PM
Pandahatch
Sep 14, 2005 08:13 AM
inspyral
Aug 28, 2003 08:36 PM
93SSPHatch
May 30, 2002 04:27 PM
