why is my spark plug oily when i pull them out?????
Re: why is my spark plug oily when i pull them out?????
its on the threads... i dont think any on the electrode or barely any if any... but threads is all oily
If the oil is on the top of the plug as opposed to the business end, then your valve cover seals are bad.
If the opposite is true, then compression test the cylinders both with (wet) and without (dry) addition of oil to the cylinder. A bad valve seal should not produce low compression whereas a bad ring or head gasket would. If a bad piston ring is causing low compression, then compression will increase in the wet versus dry test.
you probably have pad spark plug gromets/seals. go to honda and buy a new VC gasket and a set of the plug seals and just reseal it all and see what happens. the edges get hard and start to leak on them eventually
i will do this after the compression test.. THX FOR TIPS EVERYONE!!!
hopefully its the head gasket/piston rings... i read the thread of how to fix the valve stem seal n it seems like it will take time to do every single one...
ok i took off head n my hole for the header is cloged in thick sluged n oil... my valve stems on the exhaust manifold side is all burnt up... solution now??????
wow. well get new valves or clean them, clean out the ports, and replace the head gasket (since you have the head off you have to). it would be a good idea to get the valve seals replaced and have the head plained for trueness. since your exhaust valve are burned im sure its your valve seals
ok ill be swtiching them tomorrow... but where do i get them?? n where can i get the ASAP witho waiting for shipping...
the HG or valve seals??? you can from the dealer but it'll be more expensive but you can have them next day most likely. have the head sent to a machine shop also for the plaining and cleaning
so valve stems n valve stem seals can be bought at honda dealership?? i already got new headgasket bc thought it was just that at first.. estimate on cost of cleaning head at machine shop??? low on budget..
it costed me $50 to have my head plained and cleaned. thats all that was done to it. at least plained is a must!!! if not in about a year or so plan on doin another HG. i dont remember if you can get the valve seals but call and ask.
wow $50 not bad at all... any machine shop would do right?? do i have to take off my valve stems, seals, springs retainer for them to do a PLAINED and CLEAN??
no just send it assembled, request that they replace the seals and true up the guides (whatever else you want done as well). they will take care of ya
ok =D.. saves me the work then ^^.. hopefully requesting that wont go over $250 bc thats my budget line right now
phaphon
24
04-13-2017 09:00 AM
93SSPHatch
05-30-2002 04:27 PM
