what does oil on the bottom part of my spark plug mean?
Old 10-22-2010, 02:05 PM
phaphon's Avatar
Default what does oil on the bottom part of my spark plug mean?
i went to check my spark plug today cause my car has been bogging and the spark plug in cylinder number1 is all wet others had no oil on it what can be the cause of this ? im thinking its blow by? i did a leak down test and compression test b4 i put my turbo kit on the leakdown most was 14 percent forgot which cylinders and i just remember compression being good...and thanks in advance for the help
Old 10-22-2010, 02:10 PM
94 IntegraLS's Avatar
Default Re: what does oil on the bottom part of my spark plug mean?
Possibly a bad valve cover and spark plug gasket?
Old 10-22-2010, 02:22 PM
Cynical 1's Avatar
bad valvecover gasket and spark plug tube seal. about $20-30 to replace.
may want to change plugs, too, since it was bogging due to a fouled plug.
Old 10-22-2010, 02:25 PM
93egSLEEPER's Avatar
It could mean numerous things, I have a few questions to get a bit more info,
Is there oil on top of the piston?
What is the compression of that cylinder? Since the problem has started
Is your car burning oil? (blue smoke out of the exhaust)
Like said above it could just be bad spark plug hole gaskets.
What motor are we dwaling with?
Old 10-22-2010, 02:33 PM
phaphon's Avatar
have not check to see if theres oil on top of the pistons
i have not done a compression check
n its a ls turbo
the plus are like 2 months old they are ngk7 cold plugs
n no smoke
Old 10-22-2010, 02:34 PM
phaphon's Avatar
if it was a bad gasket it would be wet on top right? n mines only wet on the bottom
Old 10-22-2010, 07:17 PM
phaphon's Avatar
any more help would be greatly appreciated
Old 10-22-2010, 09:45 PM
delsolo95's Avatar
probably the rings went bad, or headgasket leaking
Old 10-23-2010, 05:56 AM
fv8s's Avatar
if it was on the top of the plug its most likely a valve cover donut gasket. anything under the plug is most likely a HG or rings like delsolo stated. perform a compression test and let us know what your numbers are
Old 10-23-2010, 07:32 AM
phaphon's Avatar
i know to do a compression test thanks but i was wondering if i can narrow it down but i guess im going to be doing a compression test thanks but the sorry part is that a compression test is not gonna tell me if its coming from the headgasket or rings or maybe even the valves
Old 10-23-2010, 07:36 AM
Retired Moderator
EsotericImage's Avatar
Well if it is one of the 3, youll need to pull the head regardless.
Old 10-23-2010, 08:58 AM
phaphon's Avatar
well i just did the compression on cylinder 1 it was 150 on a warm motor
Old 10-23-2010, 08:59 AM
phaphon's Avatar
yeah sucks cause money is really tight right now and i use my car to drive to work and school cant ride my bike cause its gonna start raining
Old 10-23-2010, 09:12 AM
phaphon's Avatar
autozone loan a tools freakn suck i cant get the compression tester out of my head!!!!
Old 10-23-2010, 09:17 AM
Colonel Cake Mix
acake em1's Avatar
when you are driving does it cut out at idle at times?
Old 10-23-2010, 09:31 AM
phaphon's Avatar
nope but i have some jg cams some idle is kinda rough at times
Old 10-23-2010, 09:43 AM
Colonel Cake Mix
acake em1's Avatar
ok well if you were getting substantial amounts of oil from a leaking gasket you would most likely feel a cut out, or jerk. so that most likely isnt the case i guess. sorry for you luck man.. but GL on the fix
Old 10-23-2010, 09:50 AM
phaphon's Avatar
yeah sucks but im just going to wait till i go back to school on tuesday and see if i can take it in to get another leak down done im thinking it can be my valves cause when i was on the freeway i was stepping on it and i accidently down shift to second it happen twice but my rev limit is only at 7100
Old 11-22-2010, 02:05 AM
malchesh's Avatar
I have a similar problem, 1995 Civic Si D16Z6 engine.
Just replaced all 4 plugs and found oil fouling on all of them, shot a torch in the chambers and can clearly see black shinny oil on the faces of the pistons.
Now I'm hoping that as it is affecting all 4 chambers and dont really get much smoke out of the tail pipe then I was thinking either Head Gasket, Valve seals or even crack breather system.
The only time I notice a little bit of smoke is heavy rev at the point where the VTEC kicks in.
Any help greatly appreciated.
Old 04-09-2017, 09:24 AM
jtabor2011's Avatar
Hello I have a 2004 Mini Cooper. I've noticed lately that I'm have a lot of oil on one of my spark plugs below the threads on one of them and the rest just have a lot of gas. Any idea?? I think the rings need replaced but aren't they at the top or am I wrong and they are at the bottom?? Any help will would be amazing
Old 04-11-2017, 04:02 AM
I like the tuna here
DumpdEJ6's Avatar
Why did you join Honda-Tech to ask about a Mini Cooper?
Old 04-11-2017, 09:45 AM
O.G. triple O.G.
NVturbo's Avatar
money is tight but you "HAVE TO HAVE" a turbo'd Honda. That sounds about right
Old 04-11-2017, 04:08 PM
yippee-ki-yay
eHMxhACk's Avatar
You replied to a seven year old post. Mr. Mini Cooper bumped a dead thread.
eH.
Old 04-12-2017, 03:02 AM
O.G. triple O.G.
NVturbo's Avatar
eH.
hypocrite much?
Old 04-13-2017, 09:00 AM
yippee-ki-yay
eHMxhACk's Avatar
hypocrite much?
Yeah, bro. Replying to your post makes me a hypocrite. But hey at least you called out a dude from seven years ago. Good job!
eH.
nengx07
20
02-06-2009 08:10 PM
VTEC_Du_Ma_Mai
09-06-2008 11:08 AM
VTEC_Du_Ma_Mai
09-05-2008 01:41 PM
B18CRacer
07-14-2004 05:06 PM
93SSPHatch
05-30-2002 04:27 PM
Quick Reply: what does oil on the bottom part of my spark plug mean?
