Need some engine guru's to help me out
Old Jul 21, 2003 | 06:12 PM
devonic's Avatar
Default Need some engine guru's to help me out
Well my car started running shitty this weekend, really bad compared to how it was. I did a compression check today and it wasn't as i had hoped.
car is a sohc 97 civic dx with a 98 ex head/intake manifold with a greddy 15g turbo kit.
Compression
4 - 65
3 - 110
2 - 200
1 - 200
my piston rings are blown on 3 and 4, you should see the oil my cars dumping out the valve cover nipple. i dont know much about engine internals so i need some help. should i just replace them with OEM?(im going back to all d16y7 motor, ditching the ex head, its been nothing but problems since i swapped it on, or should i get something else? i don't have alot to spend, this is my daily driver, if it wasn't i'd be building the block up. i just need something that will work good for daily driving but also if i wanna boost it higher than 6 psi something that can hold it
*reason they blew my charge pipe popped off friday on the highway, pulled over and fixed it but as i was i disconnected the wastegate by accident, got back on highway and it hit 14psi
any insight is much appreciative
Old Jul 22, 2003 | 02:51 AM
devonic's Avatar
Default Re: Need some engine guru's to help me out (devonic)
bump for the morning peeps
Old Jul 22, 2003 | 03:05 AM
DSF's Avatar
DSF
Well, it's according to how bad the engine is. At 14psi, you could have broken some ringlands, scored the cylinder walls, ect.
Old Jul 22, 2003 | 04:11 AM
devonic's Avatar
true, i didn't think of that
Old Jul 22, 2003 | 10:40 AM
civcexcoupeblack's Avatar
Default Re: (devonic)
Tear it apart, and see exactly what happened. I dont think it is the EX head that is to blame, would of happend with any stock head, hitting 14psi untuned. If its scored and needs to be bored out, you will most likely need to get after market pistons. Personally while it was apart, I would get pistons, rods, and ACL bearings. But if you dont want to build it, hopefully you only need new piston rings. GL
-Bill
Old Jul 22, 2003 | 11:42 AM
Evil EG's Avatar
Default Re: (civcexcoupeblack)
If its really bad just drop a B18 in there.
Old Jul 23, 2003 | 09:10 AM
devonic's Avatar
i'd like a dohc in, but its out of my price range, and the turbo makes up for that. i just need to find a complete engine, a d16y8 preferably but i'll settle with a d16y7 if i can find one
jango_night
16
Sep 15, 2011 04:44 PM
EkFG
17
Jul 9, 2008 09:47 PM
smoke traces
Feb 14, 2004 08:24 PM
devonic
Jul 22, 2003 02:51 AM
DomesticRiceMobile
15
Jul 21, 2003 07:49 AM
