Engine Gurus, I got a Question
Old Jul 21, 2003 | 06:16 PM
devonic's Avatar
Default Engine Gurus, I got a Question
Well my car started running shitty this weekend, really bad compared to how it was. I did a compression check today and it wasn't as i had hoped.
car is a sohc 97 civic dx with a 98 ex head/intake manifold with a greddy 15g turbo kit.
Compression
4 - 65
3 - 110
2 - 200
1 - 200
my piston rings are blown on 3 and 4, you should see the oil my cars dumping out the valve cover nipple. i dont know much about engine internals so i need some help. should i just replace them with OEM?(im going back to all d16y7 motor, ditching the ex head, its been nothing but problems since i swapped it on, or should i get something else? i don't have alot to spend, this is my daily driver, if it wasn't i'd be building the block up. i just need something that will work good for daily driving but also if i wanna boost it higher than 6 psi something that can hold it
*reason they blew my charge pipe popped off friday on the highway, pulled over and fixed it but as i was i disconnected the wastegate by accident, got back on highway and it hit 14psi
any insight is much appreciative
Old Jul 21, 2003 | 06:58 PM
devonic's Avatar
not in the budget, but thanks
Old Jul 21, 2003 | 07:53 PM
Poop111444's Avatar
Default Re: Engine Gurus, I got a Question (PIMPASSBEOTCH)
Did you put oil in the low cylinders and see if compression shoots up?
If its the rings, I would just replace them with Honda OEM. They are like $25 a set. Good luck
Old Jul 21, 2003 | 08:00 PM
HotWheelz's Avatar
Default Re: Engine Gurus, I got a Question (si_mekanik)
no.. he melted the rings.... i saw one at 30.. trust me 60 isn't off by much. if you take off the head you'll see the top looks like a mushroom
Old Jul 22, 2003 | 02:51 AM
devonic's Avatar
exactly, and since im going to be in there already and my pistons have 94k miles on them i mind as well replace them.
any suggestions/links to good deals? just like the progressive commerical im not trying to pay too much
jango_night
16
Sep 15, 2011 04:44 PM
smoke traces
Feb 14, 2004 08:24 PM
devonic
Jul 23, 2003 09:10 AM
turbocoupe
Nov 25, 2001 02:08 AM
