Need pics of a F series block
* B A N N E D *
1 Post
Need pics of a F series block.....(I have the f22b1) Need pics of the rear of the block prefferably out of the car.. I know, I know - dont ask.
thanks guys!!!!
B
thanks guys!!!!
B
* B A N N E D *
1 Post
Re: Need pics of a F series block (notoriousB)
Thanks man...I could be on glue, but on mine there is an allen plug below the oil filter that i thought i may be able to use for a catch can drain. Is the one up top (to the side of the filter) able to be used for Crankcase venting??? I would like to run one vent from the back of the block, and one from the valve cover to the can and have it drain back into the block. i will be using a Moroso or endyn vented can.
B
B
Re: Need pics of a F series block (bigdaddyvtec)
Do you mean the rusty looking plug from that pic? That's the coolant drain plug.
The one below the filter w/ the allen head I *think* may be pressurized, but I'm not sure. Sorry I'm not of more help...
* B A N N E D *
1 Post
I need to know where to vent my crankcase (if possible), and drain my catch can back into the block on an F22b1......
I dont see how i can do it... there are no ports like on a b series. If worst came to worst, id just vent the valve cover...installing a bigger port first (welding on a -8-10 an fitting)... But even then I dont know where to recirculate the can...
Help
Please!!!
Thanks
Help
Please!!!
Thanks
If you badly wanted to have a drain back into the engine, you could always weld a nipple onto the oilpan. It's large, wide, thin, and easy to remove
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdaddyvtec »</TD></TR><TR><TD CLASS="quote"> just vent the valve cover
and don't have it recirculate. To much moisture etc. gets accumulated.
Phil
Phil
Re: Need pics of a F series block (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote"> and don't have it recirculate. To much moisture etc. gets accumulated. </TD></TR></TABLE>
that was my experience this winter. My catch can (non-recirc) kept filling with water - was like WTF for a while then I realized it was condensation! I wouldn't want that **** getting into my oil, it filled up pretty damned quickly.
I finally ditched the can all together and just run open breather again now.
lexruger
01-27-2014 09:45 AM
