B series block fittings for catch can... where they go?
i want to run a catch can on my b16.. its my dd so i cant send the valve cover away to get bungs welded.. They sell a block fitting kit on go autoworks for the b series... its 2 -10 an adapter fittings and one plug that go into the block... where do there go on the block? are these a suitable substitute for venting the valve cover?
Re: B series block fittings for catch can... where they go?
c'mon bro there are like 1248762785619 threads on catch cans. the block fittings go on the rear of the block on either side of the oil filter. you remove to plugs (14mm allen head) and install the fittings. then attach -10 AN lines. this will work fine for crank ventilation but you may have problems with the can filling/overflowing unless you use a drain back
Hey, you see your male oil filter holder fitting? My b16 block looks just like this, and I cannot figure out how to install the stock oil cooler over this. The fitting for the oil cooler is already a male end, which is supposed to thread INTO the block, sandwiching the oil cooler to the block. Then the oil filter threads onto THAT. But this male "oil holder" as honda calls it - wont allow installation of the oil cooler. Does this existing fitting thread out of the block? I dont want to screw the threads using vise-grips only to find that this thing wont come out!
where do you drain back to? having that overfillin problem
You dont need to have have it go into the oil pan... If youre catch can is equipped with a drain valve on bottom of catch can you can just tee into one of the lines from the back of block to catch can. You just have to make sure the catch can is mounted as high up as possible in the bay.
So wish i would have done this when I had the motor out... what a pain in the **** to get to... I got a b16b in an ej1 and I'm trying to put the go auto works block vent kit in but it looks like I have to take off the intake manifold to get access... Any other ideas?
Intake manifold isn't hard to take off at all.
If its your first time take lots of pics before anything.
Keep all the bolts in zip locks
Who is Mr Robot?
put the car on jackstands and do it from under the car?
I suggest you read the catchcan thread and not bump a 4 year old thread, as more than likely no one will give a useful reply
junkyardd16z6, PMd you with some help.
