hole in block?
hole in block?
my question is there is a hole in the back of my b16 block right next to the oil filter. it looks like a perfect circle that is imbeded. i have seen other blocks with that hole plugged, but was wondering what that seal was called, and how do i place another one in. would i have to take it to a machine shop to press it in? any help would be appreciated.
http://jgenginedynamics.com/1%...d.jpg
Modified by gATOr65 at 6:17 PM 7/4/2008
Re: (sorrule)
I think that it may be a frost plug. If that is what it is, you just press another in. They are removed when a block heater is used in cold climates. You remove the frost plug and press in the block heater.
Re: (hondroid015183)
the plug is to the lower right about an inch away.
its the open plug to the bottom right of the oil filter
Modified by gATOr65 at 6:15 PM 7/4/2008
Modified by gATOr65 at 6:16 PM 7/4/2008
INCNTRL4
10
06-29-2006 07:32 PM
