need mad crazy help!!
Old 11-12-2006, 01:43 PM
teknikEG6's Avatar
Default need mad crazy help!!
Well after my car sat for 3 months all torn apart. I put back together with the only new additions being: headgasket. Golden Eagle head studs. a hondata intake gasket and new timing belt.
Now we start the car. Runs 10 flat A/F's and is burping and is spitting black smoke like nothin. . .any helps on what to do???
oh yea and i was using ngk 9's then put in 7's because I was told they dont foul as easy
its a b18c1 with stock everything, plus turbo
Old 11-12-2006, 01:44 PM
B A N N E D
chasemyhonda's Avatar
what are you using for Engine management? sounds like you need to do some tuning on that car.
Old 11-12-2006, 01:55 PM
teknikEG6's Avatar
im using cromepro. but the tune was good before i tore it down.. . .
oh yeah and it has a solid CEL will not blink...
Old 11-12-2006, 01:56 PM
B A N N E D
Might have got a ban burn and put into limp mode
Old 11-12-2006, 01:58 PM
teknikEG6's Avatar
Default Re: (blindingxenon)
a ban burn? whats that mean
Old 11-12-2006, 02:09 PM
beepy's Avatar
Default Re: (teknikEG6)
A baD burn.
I don't think that's your problem. If you had the car torn apart you probably just missed an electrical connector. Like the MAP sensor. Or an ECU connector. Double check all of your connections. See if any oxidation of the connectors has occured since you took it apart.
Old 11-12-2006, 02:20 PM
JDMisGOOD's Avatar
Default Re: (beepy)
Sounds like a bad burn or something isn't plugged in correctly.
Old 11-12-2006, 09:06 PM
teknikEG6's Avatar
bad burn on what?
Old 11-12-2006, 09:08 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknikEG6 &raquo;</TD></TR><TR><TD CLASS="quote">bad burn on what?</TD></TR></TABLE>
Bad burn on the chip.. or the chip has went bad
Old 11-12-2006, 09:16 PM
teknikEG6's Avatar
can that happen from not being ran/used for months, before the chip was fine..
Old 11-12-2006, 09:21 PM
boston's_rex's Avatar
Double check the timing belt, just an ideal.
robbywk
Engine Management and Tuning
05-17-2013 08:47 AM
TurboCoop
04-10-2006 01:59 AM
ZCHF
08-12-2004 11:32 AM
VTgringo
08-19-2003 05:01 AM
Quick Reply: need mad crazy help!!
