cel w/no code......engine falls on its face. please help!!!!!
Old Aug 18, 2003 | 04:41 PM
VTgringo's Avatar
Default cel w/no code......engine falls on its face. please help!!!!!
I am getting a random cel, when this happens the engine falls flat on its face. this will only last a second or two and then it drives fine again. when i stop to check the cel on my ecu there is no code. the car really isn't driveable, and sometimes it will stall. i really need help, i am suppose to be driving back to school (3hours) tomorrow.
Old Aug 18, 2003 | 07:30 PM
VTgringo's Avatar
Default Re: cel w/no code......engine falls on its face. please help!!!!! (VTgringo)
bump......i spent the past two hours looking for posts, this is a serious hesitation
Old Aug 18, 2003 | 08:11 PM
hybridsol's Avatar
Hondata?
Just read your "other" post- don't know much about zdyne ECU but it sounds like you are overboosting and going into limp. Do you have the MAP check valve? or does the Zdyne allow you to go up to 11 psi?
Oh, and it sounds like you fouled your plugs too.
Modified by hybridsol at 12:36 AM 8/19/2003
Old Aug 19, 2003 | 05:01 AM
VTgringo's Avatar
Default Re: cel w/no code......engine falls on its face. please help!!!!! (hybridsol)
i would guess the zdyne is very similar to hondata. both use the stock ecu modified in some way. maybe its a setting on the map sensor, but i have a 3 bar map sensor and the computer is tuned to run that. what does limp mode feel like? is it random or does it happen at a specific rpm everytime, because my situation is very random and it always occurs once the engine is up to temperature. thanks
hondalove414
Mar 20, 2011 08:11 AM
boostedSI90hatch
May 22, 2007 04:25 PM
peedee
Mar 29, 2007 08:09 AM
ElectronMan
Jun 9, 2003 07:48 AM
White98LS
May 4, 2003 08:12 PM
