need input on my ls vtec turbo setup
Old May 21, 2009 | 08:35 AM
b20forlife's Avatar
Default need input on my ls vtec turbo setup
Well I am almost done with my setup and almost ready for tuning. This is my dd so reliability is a must. Lmk if I should change anything. I am shooting for 400whp. Here's my setup
Wisco 10.5 pistos
Eagle rods
Acl race bearings
Ge block guard
Stock gsr port head
Blox stage b cams
Blox retainer
Blox dual valve springs
Msd distributor cap
Msd exter coil
Msd rotor
Sk2 intake manifold
Msd 750 injectors
Peakboost ramhorn
2.5 intercooler pipping
3" down pipe
44mm tial wastegate
50mm tial bov
Blox boost controler
Garret gt3076r turbo. Duall ball bearing
28x3x8 intercooler
Let me know if I should change anything or if I'm missing anything
Old May 21, 2009 | 11:33 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: need input on my ls vtec turbo setup
your pistons? why so high?
I'm not Rick!
thats gonna be mad power. whats your software you plan on using?
Old May 21, 2009 | 11:47 AM
omgwtfbbq's Avatar
Since you're talking reliability, you may want to get some lower compression pistons....just a suggestion.
Old May 22, 2009 | 10:35 AM
I'm not Rick!
for sure. thats what i did. i gots 8.8 or 9.1ish.
Old May 22, 2009 | 12:29 PM
brian...'s Avatar
No that would be stupid. Leave the high compression and run on e85. As long as you don't have a retard doing your tune it will be just as reliable, and you wont have to run 20lbs of boost to make that kind of power.
Old May 22, 2009 | 01:26 PM
TheShodan's Avatar
Moderator
Correct. depending upon turbocharger used. I saw no horsepower goal.
Old May 29, 2009 | 07:23 PM
b20forlife's Avatar
cause i tought the higher the compression the more power easier right?
i plan on using neptune since i already have it
I will run e85. how much boost before i can reach 400-450? and joe at locash tuning in arizona is tuning it. he has tunned plenty of cars and is the best in az
HORSEPOWER GOAL IS 400-450 since i have stock sleeves. and the turbo is a gt3076r
anyone else have some more input as i am ready to go to tunning as soon as i have money
Old May 29, 2009 | 08:14 PM
eg:R's Avatar
e85 and 15lb should get you there
Old May 29, 2009 | 08:59 PM
tek_civic's Avatar
Well MY biggest concern would be
Ge block guard
These typically get mixed reviews.
If installed incorrectly its worse than having nothing at all. They can be trickey to install even for experienced engine builders(the classic guys dont deal with this stuff at all) and a little mis alignment or tight clearence=bad news.
Old May 29, 2009 | 09:26 PM
Ryank327's Avatar
Actually suprisingly the high compression doesn't make that much of a difference at all. Nothing dropping down to 9.0:1 and adding another pound of boost wouldn't recover. I've actually seen dynos to prove this and suprised the hell out of me to.
Old May 31, 2009 | 06:10 PM
b20forlife's Avatar
well i have my bottom end put together so i dont want to buy new pistons
Old May 31, 2009 | 06:34 PM
TheShodan's Avatar
Moderator
I would use something slightly larger requiring less boost and heat, but it may change the characteristics you're looking for.
Old Jun 26, 2009 | 04:32 PM
b20forlife's Avatar
anyone else want to input? going to get tune in a month
JDM97R
Jul 22, 2009 09:06 PM
Pandahatch
Feb 2, 2008 02:27 PM
paul93sir
Oct 13, 2004 05:06 AM
94SupraTT
Feb 21, 2002 12:41 PM
