Need help with Profec B
Old Aug 7, 2002 | 08:58 AM
blackteg's Avatar
Default Need help with Profec B
I have already done a search and it didn't realy help any. I have the Profec installed and turned on and the balance set to 12. I have Hi and Lo boost set to minimum. The problem is that it doesn't limit the boost at all. The boost just goes higher and higher. It does the same thing when I turn it off. I have the back of the Profec teed in with the FPR. The IN on the black box goes to the turbo. The OUT goes to the side port on my TIAL. I have already checked the seitches and they appear to be set correctly. What am I doing wrong?
Old Aug 7, 2002 | 09:03 AM
Adi Radoncic's Avatar
On Fire!
Default Re: Need help with Profec B (blackteg)
First of all are you working with a internal or external turbo here..??
You shouldn't have to connect anything to the turbo, you should just have the line from the top of the wastgate and the side port hucked up.
Adi
Old Aug 7, 2002 | 09:06 AM
Doodoo's Avatar
http://www.greddy.com/Technical/profec_frame.htm
This should help
Old Aug 7, 2002 | 09:19 AM
blackteg's Avatar
Default Re: Need help with Profec B (newgsr)
External Wastegate. I can't use the top port on my TIAL because I can't close the hood then. Without the boost controler I had a line from the turbo to the wastegate side port if that helps any.
Old Aug 7, 2002 | 09:23 AM
On Fire!
I personally don't think that there is any other way of hooking the controller up without having the top port of the wasgate hooked up to the "out" port on the black box.........
Adi
Old Aug 7, 2002 | 09:25 AM
blackteg's Avatar
So what do I connect to the side port and what do I connect to the top port?
Old Aug 7, 2002 | 09:39 AM
On Fire!
Ok hook the top port to "out"
Hook the side port into the intake manifold
Hook the fitting thats on the intake side of the turbo to the "in" port on the black box
Than just run a line from the intake manifold to the incar boost controller itself...
Adi
Old Aug 7, 2002 | 02:20 PM
niedejb's Avatar
Ive got the compressor nipple going to the in and the side port of my tial going to the out.
Works great.
Old Jun 26, 2004 | 08:00 AM
Sohc Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">
Adi </TD></TR></TABLE>
Bump..back from the dead.....
So what do you do if you don't have the vaccuum port on the compressor of the turbo?
Khoi
vesperfx
Sep 13, 2008 06:35 PM
EJ8 GSR-T
Jan 17, 2006 01:17 PM
W.Zero
Jan 16, 2005 02:49 PM
Haleiwa-Brando
Oct 4, 2004 08:21 AM
boostedel
Feb 22, 2003 02:37 PM
