help tial waste gate problems
Old Jan 14, 2005 | 05:50 PM
W.Zero's Avatar
Default help tial waste gate problems
i just installed my old turbo kit on a friends car which i have a boost controller and he doesnt. the wastegate is a 38 mm with a 10 lbs spring. i hooked a vaccum line from the turbo to the wastegate and no mater which on i put it on, either the top or side, it will not boost to ten. from what i remember without a boost controller the line should be connected on the side right?
if there is a diagram some one knows of to hook up would be nice thx
Old Jan 14, 2005 | 06:03 PM
f22b2tdave's Avatar
Default Re: help tial waste gate problems (W.Zero)
does he have a front mount? seeing as your reading before the ic, you may be seeing a pressure drop, how much boost can you build with it? try a line off the intake manifold.
dave
edited for bad judgement on which port to use
Modified by f22b2tdave at 10:23 PM 1/14/2005
Old Jan 14, 2005 | 06:22 PM
Syner-G-Racing LLC's Avatar
your right, you hook up the side port to the turbo and leave the top port to vent to the atmosphere or you can hook it up with a boost controller.
as far as the boosting problem...it sounds like its leaking, check the intercooler and charge pipes along with the boost gauge tubing and pressure source. if your still not holding 10 psi the spring may be messed up (cracked, a coil broke off, or just unsprung) or check the diaphram and the valve and gasket seal, you can check it with a air pump.
Old Jan 14, 2005 | 08:12 PM
W.Zero's Avatar
Default Re: help tial waste gate problems (Syner-G-Racing)
he has a one series b16 so it only has one place for me to tap which was the top of the factory FPR. he's going to order the GE vaccum box which ill then hook it up to the brake booster vaccum. i just tee'ed the vaccum to his fmu, boost gauge, factory FPR, and BOV....lol if this is the problem can some one explain why that would effect the WG if its connected straight to the turbo. id understand if there was a boost controller but hey hope this GE thing works.
Old Jan 14, 2005 | 09:11 PM
tub_sephiroth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">your right, you hook up the side port to the turbo and leave the top port to vent to the atmosphere or you can hook it up with a boost controller.
How do you check it with an air pump. I'm having the same problem.
Old Jan 16, 2005 | 01:42 AM
Default Re: help tial waste gate problems (tub_sephiroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">
How do you check it with an air pump. I'm having the same problem.</TD></TR></TABLE>
if you have a dump tube bolt it to the bottom flange and wrap the air nozzle with tape or rubber to form some what of a seal in the dump tube and blow. if you have a gauge on the air hose you shouldnt feel it dump air until the set spring pressure normaly 7psi on the standard wastegates. you get the idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W.Zero &raquo;</TD></TR><TR><TD CLASS="quote"> he's going to order the GE vaccum box which ill then hook it up to the brake booster vaccum. i just tee'ed the vaccum to his fmu, boost gauge, factory FPR, and BOV....lol if this is the problem can some one explain why that would effect the WG if its connected straight to the turbo. id understand if there was a boost controller but hey hope this GE thing works. </TD></TR></TABLE>
I highly recommend the golden eagle vacuum manifold. it works great and realy cleans up the engine bay. especialy when get all those t's going on in there.
Old Jan 16, 2005 | 02:18 AM
flip1199's Avatar
are u sure u installed the metal ring between the gate and the mani?
Old Jan 16, 2005 | 06:08 AM
W.Zero's Avatar
Default Re: help tial waste gate problems (flip1199)
it works now. it was the intercooler pipping. thx for the help
Old Jan 16, 2005 | 10:14 AM
What was wrong with your intercooler piping? Was is loose?
Old Jan 16, 2005 | 12:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W.Zero &raquo;</TD></TR><TR><TD CLASS="quote">it works now. it was the intercooler pipping. thx for the help </TD></TR></TABLE>
Old Jan 16, 2005 | 02:49 PM
W.Zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">What was wrong with your intercooler piping? Was is loose?</TD></TR></TABLE>yeah one of the pipes was loose lol.
Lao17
Apr 2, 2011 05:28 PM
Markb16a
Jun 27, 2007 08:42 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
99silverbullet
Jan 3, 2004 06:28 PM
Bottoz
Dec 10, 2002 07:23 PM
