need help find out why it doesnt boost more
Old Jul 3, 2005 | 11:36 AM
SwIntegraB16's Avatar
Default need help find out why it doesnt boost more
hey guy i need ur advise well im having a lil problem i cant get my car to boost more then 8psi bc is set up my boost controller to 10psi but it doesnt get there can some one help me out i have a t3/t04b turbonetic i have the drag turbo kit with the Turbonetics Deltagate Mark II Wastegate (7 PSI Spring) and when i had no boost cotroller it would never go to 7psi it would go like 6psi and i also have a down pipe 2.5' but then my exhaust is like 2.3' does any can tell me why is this happining to me need some help why it wont boost
Old Jul 3, 2005 | 12:07 PM
Johnyquest's Avatar
Default Re: need help find out why it doesnt boost more (SwIntegraB16)
Could be a ripped charge coupler, otherwise it's pressure loss through the intercooler ... try tapping boost reference off the manifold if all else fails.
Matt
Old Jul 3, 2005 | 12:09 PM
kameleon23's Avatar
What vacuum source did you use for your wastegate?
Old Jul 3, 2005 | 02:07 PM
Johnyquest's Avatar
Default Re: need help find out why it doesnt boost more (kameleon23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kameleon23 &raquo;</TD></TR><TR><TD CLASS="quote">What vacuum source did you use for your wastegate?</TD></TR></TABLE>
He mean's PRESSURE source... like I said before.
No vacuum for a wastegate!
Matt
Old Jul 4, 2005 | 12:25 PM
Default Re: need help find out why it doesnt boost more (Johnyquest)
im using the vacuum from the turbo
Modified by SwIntegraB16 at 5:37 PM 7/4/2005
Old Jul 4, 2005 | 10:32 PM
no one else got some input on this
Old Jul 4, 2005 | 10:34 PM
D@nnY's Avatar
Default Re: (SwIntegraB16)
what kind of boost controller is hooked up to it? are you using both the top and side ports of the gate?
if you loosen that nut on the top of the gate and turn the screw with an allen wrench you can get 2 psi more from just tightening the spring down
Old Jul 5, 2005 | 02:42 PM
Default Re: (D@nnY)
im using the greddy profec b spec 2 and yeah im using the top and side vacuum but i put to boost 10psi and it only boost 8psi
Old Jul 5, 2005 | 02:55 PM
wantboost's Avatar
Who is Mr Robot?
pressure drop through the intercooler..... hook up your reference source to the intake manifold and watch your boost gauge magically read "10"
Old Jul 5, 2005 | 04:17 PM
Default Re: (wantboost)
but the thing is that im reading from my boost guage and it doesnt go to 10 neither
Old Jul 5, 2005 | 04:27 PM
wantboost's Avatar
Who is Mr Robot?
it shoudlnt
if your signal for the boost controller is from the turbo, then the wasetgate is going to regulate boost to 10 psi at the turbo outlet.... air gets heated when youcompress it, passing it through the itnercooler cools it, therefore making it more dense causing it to lose pressure (psi) so the pressure at the intercooler inlets and outlets are different, 10 at the inlet and 8 at the outlet (becaue of the pressure drop)
now your boost gague is hooked up at the intake mani, therefore its only going to read the pressure after the intercooler.
if your signal for the boost controller is plugged into the intake manifold, then the wasetgate is regulating boost to 10psi at the intake manifold.
get it?
Old Jul 5, 2005 | 07:42 PM
im going to have to take a pik so i could show u bc i have the vaccum that reads thru the ebc isthe same place as the gauge
Old Jul 6, 2005 | 12:25 AM
PinkMaggit's Avatar
Hes trying to tell you that from the
turbo-&gt;Boost Controller(boost Controller makes wastegate pop at 10PSI)-&gt; Intercooler(You lose 2psi of pressure here) -&gt; Boost Guage(reads 8psi now) -&gt;Intake manifold 8psi total going into the manifold.
Correct me if im wrong somewhere. This is assuming you have it hooked up this way.
Old Jul 6, 2005 | 06:44 AM
Dunc's Avatar
BCICAN
Default Re: (PinkMaggit)
^^^ you are right on the money. This is why hooking the boost gauge up to the manifold is "better". It just gives a more accurate reading as to what kind of pressures are actually going into the engine.
Old Jul 7, 2005 | 12:02 AM
hey guy now i have another problem but i think this is why i wasnt boosting 10psi well today i was racing some evo and my rpm we just go up but i wasnt feeling no power well so then i was onlyboosting like 4.5psi so im like what the **** so i ope the hood and saw that the bolt that goes in the wastegate was not there soo i was like what the **** so what could of happen to the bolt get loose??
Old Jul 7, 2005 | 04:59 PM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwIntegraB16 &raquo;</TD></TR><TR><TD CLASS="quote">hey guy now i have another problem but i think this is why i wasnt boosting 10psi well today i was racing some evo and my rpm we just go up but i wasnt feeling no power well so then i was onlyboosting like 4.5psi so im like what the **** so i ope the hood and saw that the bolt that goes in the wastegate was not there soo i was like what the **** so what could of happen to the bolt get loose??</TD></TR></TABLE>
I would try to help but I have no idea what you are saying....try posting in spanish
by what I think I understand a bolt vibrated out of the waste gate and the exhaust is leaking from that opening causing the exhaust to go out of the manifold instead of spinning the turbo to build boost...
Fix the exhaust leak and put in another bolt
Old Jul 7, 2005 | 05:15 PM
yeah but the bolt the got loose is the one the holds the spring so what im think is that maybe why its wants boosting all the 10psi before was bc it was leaking boost by there bc iwas not tie but thats what i think ihope u understand better sorry iwas a lil late lol
Synapse
May 1, 2007 08:42 AM
RACEPAK
Sep 19, 2005 10:44 AM
integ2
Jun 15, 2004 06:44 PM
91glassycrx
May 7, 2004 08:08 AM
cajnatc
Jun 13, 2003 07:43 AM
