B18B head on B18A block?
Old Mar 5, 2009 | 08:27 AM
beyondstock's Avatar
Default B18B head on B18A block?
Ok so I googled the question; B18a vs B18b, and b18b head on b18a. I have found that the part numbers for the headgasket are the same for both motors. However; I'm doing a build and I have came across a killer deal on a head, which I plan on buying here shortly, but its a b18b and my block is a b18a. What I'm wondering is if I can retain the ecu that I'm currently using and just swap the parts from my current B18a head over to the b18b, like distributer, water neck, sensors, injectors, intake/exhaust manifolds?
I'm going to say yes it will all work, but I want someone with a little more knoweldge to confirm this so I'm not just hoping it will work....
Old Mar 5, 2009 | 08:34 AM
dohcdelsol93's Avatar
Default Re: B18B head on B18A block?
yes, you can bolt all your b18a parts onto the b18b head and bolt it up
if your b18a is 90-91 the b18b head will flow a little better
if your b18a is a 92-93 there will be little to no difference in the performance of the two heads.
The biggest advantage you would POSSIBLY gettting out of the b18b head is a chance at a lower mileage head in better overall condition
Old Mar 5, 2009 | 08:37 AM
the head has a pnp, stage 3 valve trains, tb cams, ext ext. But thanks for confirming it!!!
kennybintegra
Aug 27, 2006 09:11 PM
DA is best
Apr 16, 2006 09:40 AM
hgw84
Mar 7, 2006 06:07 PM
JG Luder
Mar 22, 2003 07:32 PM
