need help check engine light MAP?
Old Jan 11, 2005 | 07:18 PM
nihaphan's Avatar
Default need help check engine light MAP?
well i just got a turbo'd 96 GSR.....it's throwing three codes
1.Map sensor.....it has the aquarium check valves on it
2.Rich Lean gas
3.IAT sensor
would a map sensor bypass on ebay help all this? or is it all different problems.......need help any input will be greatly thanked
Old Jan 11, 2005 | 07:24 PM
93turbo16's Avatar
hold on. We need alot more info on this subject! what injectors, fuel management, etc. If you don't have a standalone or uberdata/hondata, yuo need somethign to bleed the boost. Map sensor can't read very much.
Old Jan 11, 2005 | 09:12 PM
nihaphan's Avatar
Default Re: need help check engine light MAP? (nigaphan)
well i have the full DRAG Gen 2 turbo kit.....it came with a fuel pump and vortech fuel pressure regulator.......no ecu chip or hondata......it's running fine just needs check engine light to go away
Old Jan 11, 2005 | 09:16 PM
PrettyLude's Avatar
are you running the missing link? get hondata, and the intake air temp sensor, see if its the right plug for it, they have a couple of plugs that would fit that also
Old Jan 12, 2005 | 01:48 AM
nihaphan's Avatar
Default Re: (PrettyLude)
yea i got a ghetto check valve missing link on it right now.....might have to change the check valves......does hondata fix all the problems i have? i have a extra IAT might change to see if it will work
Old Jan 12, 2005 | 04:18 AM
93turbo16's Avatar
yea hondata or uberdata would fix those problems. And you could get rid of any FMU and get bigger injectors and have full control of ignition and fuel maps. I would look into one of the above. A conversion harness would also be needed.
Old Jan 12, 2005 | 04:59 AM
Hyaboosta's Avatar
Default Re: (93turbo16)
did you install the IAT sensor into your IC piping? Your gonna need hondata/uberdata or a Missing link to clear the map.
teggreen4
May 13, 2005 02:12 PM
lscivc
Feb 19, 2005 08:04 AM
Blanket Jackson
May 25, 2004 07:59 PM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
Pengo
Jul 30, 2002 08:43 PM
