need help check engine light MAP?
well i just got a turbo'd 96 GSR.....it's throwing three codes
1.Map sensor.....it has the aquarium check valves on it
2.Rich Lean gas
3.IAT sensor
would a map sensor bypass on ebay help all this? or is it all different problems.......need help any input will be greatly thanked
2.Rich Lean gas
3.IAT sensor
hold on. We need alot more info on this subject! what injectors, fuel management, etc. If you don't have a standalone or uberdata/hondata, yuo need somethign to bleed the boost. Map sensor can't read very much.
well i have the full DRAG Gen 2 turbo kit.....it came with a fuel pump and vortech fuel pressure regulator.......no ecu chip or hondata......it's running fine just needs check engine light to go away
yea i got a ghetto check valve missing link on it right now.....might have to change the check valves......does hondata fix all the problems i have? i have a extra IAT might change to see if it will work
yea hondata or uberdata would fix those problems. And you could get rid of any FMU and get bigger injectors and have full control of ignition and fuel maps. I would look into one of the above. A conversion harness would also be needed.
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
