NEED HELP CAR IS OVER BOOSTIN ??????????
ok my setup is a gsr wit t3super 60 a hks manifold wit a external welded on.wit a no brand wastegate tial lookalike, ok first i got the gate used from my friend.welded it on and ordered a tial small red spring from atpturbo 5.8psi they said it was. now when i drive the car first gear is 5psi second goes to 7,8 than third is like 9,10 wat is wrong here how can i fix this i searched and nobody had this problem, and on the wastegate he give me the lil nipple that screws on the top of the wastegate is missing not the port where the vac hose go the top of the gate???? is this the problem ???
Do you have a vacuum line going to the wastegate?
Sideport for manual boost controller
Topport for elec boost controller
Make sure there is not a check valve in the vacuum line also.
I'm running the Tial knock off too and was having spiking problems. Mine came with the 8.7psi spring. I replaced it with a Tial small red spring .45 bar and my wastegate holds boost perfect now. I notice you did the same as I.. so you should not be having this problem. I would look at vacuum routing...Get vacuum from a good source..like from the power steering booster. Open up the wastegate and make sure everything is tight...also make sure the diaphragm is in good working order. Good luck.
the gate only have one vac nipple i'm running it to the outlet on the turbo housing i took off the mbc and still the same thing maybe i put the spring in wrong??? can this happen
