NEED EXPERT HELP WITH TURBO
Old Jan 21, 2008 | 01:59 PM
CTR_B's Avatar
Default NEED EXPERT HELP WITH TURBO
My friend and I are trying to install his new T3 on his car and we seem to have run into a little problem. The oil feed and return are not in the up and down postion. If we were to bolt this up right now the oil return would be facing the radiator. No Im not tech when it comes to turbo but I know the return is gravity fead and needs to be in the downward angel.
How do I ajust so that it can face down?
Old Jan 21, 2008 | 02:04 PM
swappedcx's Avatar
Default Re: NEED EXPERT HELP WITH TURBO (CTR_B)
clock the turbo. Loosen the bolts on the housings and the center section will turn
Old Jan 21, 2008 | 02:08 PM
CTR_B's Avatar
Default Re: NEED EXPERT HELP WITH TURBO (swappedcx)
I know you can losen the intake side and turn just the cold side housing.
I need to turn the middle...
there is the exhaust side that has a solid ring and there is the intake side that has the little sectional clamps. But I need to turn the inside of it (middle)
Old Jan 21, 2008 | 02:20 PM
CTR_B's Avatar
Could really use your help guys!
Old Jan 21, 2008 | 02:28 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
you SHOULD be able to loosen the exhaust side too.... when you do so, the center section will turn
Old Jan 21, 2008 | 02:34 PM
CTR_B's Avatar
Default Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">you SHOULD be able to loosen the exhaust side too.... when you do so, the center section will turn</TD></TR></TABLE>
The exhaust side is a solis ring.. Not the clamp style like the intake side.
Old Jan 21, 2008 | 02:49 PM
hellakapps's Avatar
Default Re: (CTR_B)
a pic or what turbo it is would help
Old Jan 21, 2008 | 02:55 PM
agrn93ls's Avatar
X2
is there no way to loosen the exhaust side? just because its different does not mean it cant be done..
Old Jan 21, 2008 | 02:56 PM
agrn93ls's Avatar
Default Re: (CTR_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B &raquo;</TD></TR><TR><TD CLASS="quote">
........?????????</TD></TR></TABLE>
edit: NM i misread what you misspelled
Old Jan 21, 2008 | 03:09 PM
CTR_B's Avatar
Default Re: (agrn93ls)
Sorry for the typing error, I am running in between the computer and the car.
To losen the exhaust side would mean to take all the bolt out of the exhaust housing leaving only the turbine wheel holding it together. At least I thought???
Old Jan 21, 2008 | 03:46 PM
agrn93ls's Avatar
Default Re: (CTR_B)
guess I maybe misunderstand, if there are bolts I assume if you loosen them it will have the same effect if it is a solid ring or not, have you attempted to loosen the chra to exh housing bolts and turn it? I know you requested experts but I am not one, but at the same time I have yet to see anything different in design as far as how the housings are held in place to the chra.
Old Jan 21, 2008 | 05:53 PM
CTR_B's Avatar
" CHRA " ??? Sorry I am a turbo noob
Old Jan 21, 2008 | 06:01 PM
agrn93ls's Avatar
Default Re: (CTR_B)
center section, that is what it is called
CHRA center housing rotating assembly
sorry bout that
Old Jan 21, 2008 | 06:51 PM
CTR_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">center section, that is what it is called
sorry bout that </TD></TR></TABLE>
Lol well I'm still lost on what to do...
If I try and take the bolts out of the exhaust housing they hit on oil housing on the CHRA, Making it impossible to remove. i would need to turn the CHRA in order to remove the last two bolts FTL
Old Jan 21, 2008 | 06:54 PM
agrn93ls's Avatar
Default Re: (CTR_B)
you have to move the exhaust housing outward while loosining them to give them clearence, but that is to take it apart, if you just want to "clock your tubo" that is what you need to do is called, that is where you rotate everything to where you need it to be, you only need to loosen the bolts not remove them
if it is a used turbo it will be a big pain in the *** to get them to turn but they will sometimes you have to hammer them off CAREFULLY
Old Jan 21, 2008 | 06:59 PM
CTR_B's Avatar
ok I know what clocking is... In that post you bunched up all the info..
The bolts holding the keeper ring ( or w.e called ) actually go into the housing as if it is pinching together.
So your say losen all the exhaust bolts and turn the exaust housing to where it needs to be?
Old Jan 21, 2008 | 07:11 PM
agrn93ls's Avatar
Default Re: (CTR_B)
yes exactly, the ring squeezes them together so to speak. yeah seems retarded at first but, loosen bolts and turn is the theory, but its not always that easy they get stuck and you make need a mallett and possibly a vice. like i said it can be a pain but it will go
excellent little writeup the colors are not on your turbo they are used for help but read this
http://www.team-integra.net/se...=1146
if you posted a pic i could point it out using MS paint
Old Jan 22, 2008 | 06:36 AM
agrn93ls's Avatar
did that end up working for ya?
asianspeed
Dec 15, 2009 11:36 AM
Tippyman
Jun 1, 2007 02:53 PM
EkHatch1
Dec 9, 2004 08:03 PM
JoseCuervo
Sep 21, 2004 10:37 PM
Ivan
Jul 23, 2002 11:01 PM
