oil line fittings
oil line fittings
i posted this question a few days ago and i think i didn't make myself clear. i was wondering what fittings i would need for my oil feed/return lines. thanks
Re: oil line fittings (arjusmc)
I did a search...Thanks to 93LSivic here is a parts list
OK, I just spent a half hour putting together a shopping list for you. Keep in mind this is exactly how I did my feed/return system. I decided not to use the factory oil sensor because i went with a mechanical oil pressure gauge that runs off the feed "T" coming off the block. Also I used a union in the pan---drilled bigass hole and sealed with silicon, in this case Im giving you stratoseal p/n so you can do it right (which I didnt do--in light of getting turbo install done)
All part numbers are from amstreetrod.com ---best prices and parts are always in stock.
Feed:
1/8 nipple for block -- 991101
1/8 "T" -- 991701
1/8 to -4AN -- 981604
(2 needed) -4AN straight swivelseal hose ends -- 300104
(4 ft needed) -4AN ss hose -- 400040
For adapter to turbo you will need one of these depending on the size of the hole on the turbo itself.....
1/8 npt hole 982204 (Smaller T3's use this one I believe)
1/4 npt hole 982244 (This was the one I used for my t3t4)
Return:
Aluminum return flange found at turbocharged.com p/n is 20259.
-10AN flange side male to hose -- 824510
(2 ft needed) -10AN hose -- 400100
-10AN 45 to pan fitting -- 804610
-10AN union for tapping pan -- 981510
-10AN bluhead nut for union in pan -- 992410
Stratoseal for union (package includes 2) -- 178014
This should be all. Probably a little on the pricey side, but no one ever said going turbo is cheap!!
sorry if my crediting is incorrect
Feed:
1/8 "T" -- 991701
Return:
93LSivic
01-26-2004 10:10 AM
