oil feed line threads?
Old Oct 22, 2003 | 06:40 PM
redboost10's Avatar
Default oil feed line threads?
any threads on where to drill the oil feed line and do you need a feed line and return line? i searched but just found where not to drill. thanks for the help
Old Oct 22, 2003 | 06:53 PM
Seraph0's Avatar
Default Re: oil feed line threads? (tgh99si)
If I understand you correctly...
You don't need to drill anything for the oil feed. You just need to tee off an existing source (usually the oil pressure sending unit for the dash "dummy light").
You do have to drill/tap/weld the oil pan for the return. And you won't know where to put that until after you have the turbo and downpipe aligned.
Old Oct 22, 2003 | 06:56 PM
redboost10's Avatar
Default Re: oil feed line threads? (MarkC)
ok i get it now thanks for the info on that. so ill tee off my oil pressure line for the feed line and tap the pan for the return line once i get every thing on and aligned. cool!!!
elcangripapi
Dec 20, 2006 04:17 PM
elcangripapi
Dec 20, 2006 04:16 PM
PrecisionH23a
Jun 16, 2002 07:53 PM
