need expert opinion on this fuel problem
Old Sep 4, 2002 | 04:58 PM
mannysir's Avatar
Default need expert opinion on this fuel problem
got a problem and need some help. i was recently running 310 injectors and an 8:1 fmu on my turbo setup with everything you see on my setup below. the car boosted strong but ran very rich and like crap. now, i blew my 310 injectors and put back my original 240's and the car runs great. but now i am afraid i will run lean when i boost. can i boost safely with the 8:1 disc or should i go with a 10:1 or even a 12:1? or will i be fine with an 8:1 but richen up with my apexi v-afc up high? by the way i am boosting 7psi on this setup. please give me some feedback.
Old Sep 4, 2002 | 07:16 PM
Hellz99si's Avatar
Default Re: need expert opinion on this fuel problem (mannysir)
Well~ I'd go with a 12:1 BUT Only for a little bit while you're saving for bigger injectors...The stockers won't last long with that amount of stress
Old Sep 5, 2002 | 02:24 PM
mannysir's Avatar
i aM asking if i could run safely with my 8:1 disc and 240's, can anyone help me withn this?
Old Sep 6, 2002 | 02:43 PM
mannysir's Avatar
no one here is able to help me
Old Sep 6, 2002 | 03:29 PM
blu_si's Avatar
Let me tell you from my experience. I have a b16 with a drag 3 kit, which i believe comes with a 10:1 vortech FMU. I was running my stock injectors and a stock fuel pressure. I ended up blowing the high pressure fuel line that goes from the fuel filter to the fuel rail. I was talking to the guys at honda and they said they are only made to withstand 100psi or so of fuel pressure. So if that tells you anything may you should stay where you are at and keep the boost turned down. And oh yeah i was only boosting at like 8psi.
Old Sep 8, 2002 | 05:49 AM
DA666's Avatar
Default Re: need expert opinion on this fuel problem (blu_si)
right on....too much pressure for stock oem issued parts.
mainly injectors
ARACER25
Aug 4, 2003 06:21 PM
jmad08
Jul 30, 2002 10:02 AM
OneScarySOHC
Jun 9, 2002 01:21 PM
BoostedSi
Feb 15, 2002 01:31 PM
Tr0LL
Sep 14, 2001 10:54 PM
