6.5 psi and stock injectors?
I would think the stock injectors could handle such low boost. Or would they just be working too hard? I was thinking of running 310's.
Re: 6.5 psi and stock injectors? (sando112)
You're probably running the fmu, inline pump, and stock injector setup. The 12:1 ratio should keep you in the safe, rich zone, but you never know until you dyno and tune the fuel one way or another. Definitely, don't boost any higher than 6.5 psi. The 12:1 setup will give you crazy high fuel pressures at those boost levels. Upgrade the injectors as soon as you can. I'm in the process of converting from your setup to 310cc's and s-afc; only the fact that I'm broke has kept me from doing it sooner.
310's would be better
Re: 6.5 psi and stock injectors? (Teg4e)
GOLDBERG
04-13-2003 05:16 PM
red civic standard
11-08-2002 07:12 AM
Tr0LL
09-14-2001 10:54 PM
