Need advice on a new turbo setup
Old Nov 17, 2003 | 07:57 PM
TurboB18C1's Avatar
Default Need advice on a new turbo setup
Car: DC2 b18c1 built
street driven
currently:
Greddy kit tdo5-18g (1.2Bar , 17psi)
Hondata
850cc
Target HP: 420-480 Wheel horsepower
I will have about 3gs to spend on a new kit by Christmas and I want to know what you Honda-tech members suggest I should get?
Old Nov 17, 2003 | 08:24 PM
gritsak's Avatar
Default Re: Need advice on a new turbo setup (TurboB18C1)
for any good answers..more info is gonna be needed.
1. do you want to make that on pump or race gas?
2. by "built" do you mean sleeves? if so, is it bored?
3. are you looking for a whole new kit? or just new turbo/manifold?
4. what boost do you want to make the power at? (which will reflect if you want it on pump or race)
5. do you want to keep a/c, p/s? if you still have them?
Old Nov 17, 2003 | 08:33 PM
TurboB18C1's Avatar
Default Re: Need advice on a new turbo setup (gritsak)
This Power would be made on 100 octane Fuel
This motor is not sleeved but has a block guard
JE pistons 9:5:1 / Cower Billet rods
Just a Turbo and a Manifold (Love Fab sst) External Waste gate
25-29 psi
Ac is out already and so as the PS
Old Nov 17, 2003 | 08:38 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">This Power would be made on 100 octane Fuel
25-29 psi
damn, 25-29psi on stock sleeves...you either got some big ***** or an awsome tuner..
i would look into an sc61 in your situation, it will make what power you are looking for at a much safer level..it should do around 420 at around 20psi, and upper 400's at 25
and you should definitely up the octane if you are gonna do this, 100 isnt gonna cut it
Old Nov 17, 2003 | 08:44 PM
TurboB18C1's Avatar
This meamber said that you can run the 20 psi range on stock sleves as long as the tuner is good.
jinxproof99
Forum ****
Offline
5648 posts [98%]
Re: can b18c1 or b18b stock sleeves handle 330whp or so? (reignofchaos) 3:41 PM 11/10/2003
Quote, originally posted by reignofchaos »
hm... which block is stronger or better?? i assume b18c with the piston coolers etc..
can the b18c1 take 15-17psi daily and handle say 330whp or so with stock sleeves??? i assume i will need new piston's rods and the studs head gasket etc etc but how about sleeves??? i plan to use aem ems or somethign similar
you can run 300 to the wheels if tuned right with ease on a stock b18c1 block. you can run 550+ to the wheels and make it last for more than a year of hard street/track time on a b18c1 with stock sleeves, forged pistons and forged rods. the b18c1 and b18c5 blocks are the strongest as far as running them stock. its all in the fuel delivery and tuning.
Old Nov 17, 2003 | 08:55 PM
gritsak's Avatar
im familiar with his car, but i wouldnt base the reliability of a high 400whp stock sleeve honda on one car...theres been tons more that have blown their motors on less power.
i do agree with that its all in the tuning but theres tons of variables within that.
my friends car with i helped build made 380whp on stock sleeve at 18psi, it could have gone over 400 but had a leak and some other limiting factors. so i know personally that stock sleeves are capable of good power with a good tuner.
and ill tell you another thing, if your gonna do it, get some c16, sunoco 118, or some kind of good high octane gas when you are running higher boost
Old Nov 17, 2003 | 09:02 PM
tegmech's Avatar
sc61 turbo, lovefab sst or sidewinder with a full exhaust, high flow cat, better ic(precision maybe???)
Old Nov 17, 2003 | 09:10 PM
TurboB18C1's Avatar
thanks for your replys it has helped me alot
another question is how well does the GT2835R compare to a SC 61 and if i do decide on the SC 61, what is the maxium psi output
i will probley get a AEBS T-Sleeve Engine Work done to my block but will not bore just keep the 1.8 L
NOT ON A DYNO JET but on a dyno dynamics dynamometer (Vishnu Performance)
as of now on the dyno with a 15 psi run i registered 246.6 hp(pump gas) at the wheels which is of a boost leak which drops my boost to 10.5psi occuring at 5500 RPM so i only get 15 psi at the bottom end not top end. also we could not advance the timming on pump gas as much as we could of done on 100 to 116 octane fuel.
so for my next run i wanted to setup something more that will face my target HP.
Old Nov 17, 2003 | 09:13 PM
TurboB18C1's Avatar
Default Re: (tegmech)
already have full exhuast 3" all the way from the downpipe to the muffler
IC greddy Type 24
CRXherbie91
Dec 8, 2012 01:10 PM
honda_ek9
Jan 19, 2011 12:39 PM
lsvtec225
Mar 3, 2007 06:59 PM
Pandahatch
Jan 11, 2007 12:10 PM
Blazin Civic
Jun 6, 2004 02:20 PM
